06 2500 Hd Crew Steering Noise: Dealer Says Cant Be Fixed
I have a 06 Silverado 2500HD crew 6.0 4x4 shortbed. It has the rattle in the steering column when turning to right at low speeds and often makes a 'pop' noise when turning from a parked position or when parking and turning wheel.
My dealer has been good, they have replaced the I-shaft twice, replaced the steering gear, and the lower bearing that I know of but it still does it...the noise and when it does it has changed after each part replacement but it has always had a noise since I bought it at 19k, it now has 25k.
GM's tech assist dept. is now telling them the I-shaft fix doesnt work on a crew cab like mine and that they are working on a new fix but at this time I will have to live with the noise and check back with dealer occassionaly.
I have had an 01 1500HD crew and an 05 Avalanche that both had this problem and both were fixed by either lubing the shaft or shaft replacement.
Has anyone else been told this?
This noise is driving me crazy...I cant believe I have to live with this on a 25,000 mile truck! I am going to post in tech forum too.
Any thoughts???
My first thought was Intermediate Shaft replacement time. But it looks like that's been ruled out. Does the steering wheel vibrate or anything when you go above like 35-40? On a long shot, it could be a right side wheel bearing.
I have exactly the same truck. The dealer has replaced the I shaft after the repair didn't fix it. Also I had the power steering pump replaced as well as the steering shaft bearings. I don't have a pop noise but other weering noises at low speeds. I just went out of warranty but these steering noises are driving me nuts.
Hockey, I hadnt thought of anything like that but the truck drives perfect, no vibrations or anything other than the rattle.
Searay, I agree on the noise! Very annoying to have a noise that makes you feel like your driving something with 200k miles and it only has 20-30k miles.
Thanks guys.
Any others?
I just replaced my 03 sierra 1500 with an 09 sierra 2500HD yesterday. I too have noticed a sort of clunking/rattle that seems to be only felt in the steering wheel when i hit bumps. I think im going to go drive another on the lot to see if it does the same thing. My 03 used to have this and they would re-pack the grease and it would be fine for a bit. Finally they had an updated part to install and i never had the issue again. My new truck had 270 miles on it when purchased.
Thanks guys.
Any others?
Brought it in and they determined the Intermidiate Steering shaft was junk. Also my RR speed sensor is junk causing my ABS and Stabilitrak WIL to come on. Being fixed on friday
Could also be the bearing where the steering shaft goes into the steering box but the symptoms sure sound like the intermediate shaft.
I had the same problem with my 2005 gmc 2500HD. The problem is not the steering shaft. the problem is the plactic sleeve with a bearing inside. the sleeve does not fit tight in the metal tube. What I did was remove the sleeve. Then I took a pop can cut it the right size to rap around the sleeve. Its a little diffucult to get back in but it fixed my problem. The clunk always drove me crazy.
Where is this plastic sleeve? I am not following exactly what you did. Thanks, Jeff
The Plastic sleeve is under the dash. If you go under the dash where the steering shaft comes through the firewall. remove the bolt that attaches the steering shat to the bottom of the steering column. Then slid the steering shaft down. Then you will see a plastic ring at the bottom of a metal tube. Slide the Plastic ring out which is the sleeve with the bearing inside. Then Rap the pop can around the sleeve and slide it back in. I only had to use a single layer of aluminum pop can you may need more layers if it is really loose. Hope this makes sense.
Thanks!
Thanks!
Let me know how it works for you.
If there is slack around the plastic bearing, will it be noticable when moving the steering wheel while looking up at the bearing & shaft? Mine seems to have zero movement around the outside of the plastic bearing or where the shaft comes through the plastic ring. Just wondering if I could see movement if it has slack without taking the I-shaft back out to remove the bearing.
What I would do is grab the steering shaft with you hand and wiggle it, while looking at the bearing. You might need to remove the bolt. I believe it was a 15mm socket. Then grab the shaft and see if there is any movement.
    • This video may not be the exact content for the joke thread but its a lot of laughs so here it is, I've only watched a portion of it so far but if anyone is looking for some light hearted good soap box driving action, its here. As a note in the upper left of the screen it shows the number out of 100 to refer back to any particular vehicle for comment !.    https://www.facebook.com/reel/1351928276956715
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • As a matter of amusement I’ll leave this conversation with this. Do you beat the government average fuel estimate? Statistics are a guide to me. Not a rule. Someone once said I have to have the last word. If true and possible may be. I’ll blame that on working in a family business.
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
