Ratteling Noise
For years I've had a ratteling noise coming from my dash and could never pinpoint it until now. Over the winter the noise became alot more irritating and louder, usually started at 50 mph and go to 80 mph. Turns out it was the instrument panale, which GM has a recall for. So I had the dealer reaplce the $300 peice for no cost, and asked exactly what peice in the instrument panel causes the rattle and he told me that it was something with one of the guages and comes loose, or falls off. He also said with my truck that there is another rattle that is caused by the throttle cable on the firewall by the throttle cable.
Well after the new instument panel was installed and reprogrammed with my current mileage, the loud rattle noise was no longer there when I git 50 mph. But I did notice a slight rattle noise coming from dash again when I hit 60 mph. It had the same sound as before, but alot less quiet. It must be the throttle cable causing this like the tech said.
GM sent me a motice regarding recall of instrument panel last year. If your vehicle is under 70,000 miles GM will replace it for no cost. I also found out that GM has extended it over 80,000 now, they will cover the cost of the instrument panel, but you would have to pay for the labor. They said it takes about an hour or so to do the install and reprogramming. Also found out that if your instrument panel ever blows out, that the LED bulbs that are in it cannot be replaced becuase they are soildered in. The fix is having to shell out $300 for a new instrument panel, which the dealer would have to do, because they are the only ones that have the software to input your correct mileage, or so I was told.
    • Correct.  2019-2021 model years are serviced by a different p/n.  19420611.  Recall 2021s use 19420611.   The recall engines 2022-2024 model years are serviced with 12740076.     The difference between 19420611 and 12740076 is GM changed injector size for 2022.  The injectors are smaller on 12740076 with smaller injector bores in the cylinder heads to match the smaller injectors.  So you can't install a 19420611 in a 2022-2024, and you can't install a 12740076 in a 2019-2021.     Both engines are the replacement engine p/ns that are in the L87 recall.  So both of these are the updated engines.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
