Will 07-08 Nav Unit Work In 09
i have tried to search the issue
i just don't want to loose any features
i didn't know if i got a 07-08 nav unit, i might not have BT or onstar anymore?
i have bose, so i should be ok on the door chimes and volume.
does anybody know the part # for the 09 nav unit i need to look for
i have 09 gmc sierra with bose and bt
thanks for the help
Yes, I think it should work. I just put a new '09 unit in my '07. Everything works great without programming, as long as you don't want your XM or OnStar. All other features work great. If you get a new unit, you will not need to get dealer programming to unlock the Theftlock as your truck's VIN will be the first stored in the unit. If your unit is new, you will only need programming to:
a) have the new unit recognize your XM module (make sure you jot down the XM Unit # off of Channel 0 before disconnecting your stock unit)
b) have the new unit recognize your OnStar module
c) If you get a DVD unit, have it programmed to read "Region 1 NTSC" regional DVDs.
I'm taking mine in for dealer programming on Thursday, ONLY because I can't live without my XM. OnStar and DVD playback I don't really care about, but it will be nice to have them back.
Now, if you buy a unit that is used or has been previously installed, you'll definately need to visit the dealer to program everything (remove the Theftlock, configure the radio, etc.etc.etc.)
Oh yeah, the Part # of the 2009 Unit I installed: 25891155
thanks for the info
i was told that if i did not get a 09 nav unit that i would loose my factory bluetooth.
has anyone heard this?
maybe some of you factory guys have the facts
thanks
