Rear Block Options?
OK.. I was screwed up on the hieght of the stock 07' rear blocks... they are not 2" as the Ready lift box claims they are 1.25"s ... I want to add about an inch to 1.225 inches of height to the rear of the truck. Ready lift sells a kit for 139 bucks... I've found a few blocks for $39 but no square ubolts... What gives? Is Ready Lift the only player in this market? Help a brother out... I've all ready installed the leveling kit up front so a total package is out of the question...
Found these blocks from super lift...but they too dont show the square U-bolts.
Superlift Blocks
Was alos looking at this option to raise the rear end after i put on the leveling kit on front end just not sure how well this works or anyhting.(no experience with it)
Rear Leaf
Site has alot of "lift blocks" but not seeing hardware with them.
Lift Blocks
Superlift Blocks
Rear Leaf
Lift Blocks
Look here for Universal Blocks...
Has anyone had any dealings with the company I have linked above?
There is a truck shop in town here that will custom make u-bolts for you for about $15. If there's a truck shop near you, give 'em a call.
Thanks! there is a shop in Longview that will do that!
ReadyLift® OEM style rear block kits are now available for model specific applications. These Rear Block Kits include (2) Rear Blocks, (4) E-Coated U-Bolts, (8) Nuts and Washers and will safely lift the rear of your Truck an additional 1” to 3” depending on application. Based on OEM designs and never made out of light weight extrusions our 3" GM Blocks are made from cast iron and have Anti-Rotation ears built-In. Fits 1999-2009 classic and new body style 6-lug model GM trucks. New models with OEM 1.25" blocks will want to take advantage of the additional 1.75" of lift for towing and hauling, particularly when using a front leveling kit. Eliminates the dangers of having to stack blocks which can be illegal in some states.
http://www.readylift.com/c-120-silverado-s...-block-kit.aspx
http://performancelifts.com/cgi-bin/cart/search.html
do a search " u bolts "
ReadyLift® OEM style rear block kits are now available for model specific applications. These Rear Block Kits include (2) Rear Blocks, (4) E-Coated U-Bolts, (8) Nuts and Washers and will safely lift the rear of your Truck an additional 1" to 3" depending on application. Based on OEM designs and never made out of light weight extrusions our 3" GM Blocks are made from cast iron and have Anti-Rotation ears built-In. Fits 1999-2009 classic and new body style 6-lug model GM trucks. New models with OEM 1.25" blocks will want to take advantage of the additional 1.75" of lift for towing and hauling, particularly when using a front leveling kit. Eliminates the dangers of having to stack blocks which can be illegal in some states.
Thanks for the information. Although most will want the additional height, I'm really only looking to put an additional inch or so in height to the rear. Most more than likely I'm going to have the custom shop in the neighboring town make me a set of custom blocks and u-bolts. I put the ready lift leveling kit on the truck to get away from the severe rake look. I dang sure am not gonna spend hard earned green backs to put all of the rake back in. Having had back surgery in 05 the higher I make the rear of the truck the more trouble I have getting in and out of the bed, and the more likely I'll re injure my self.
Obviously you more than likely work for Ready Lift. The leveling kit is a great product. However, the vague advertising campaign and no model specific information available for the rear lift blocks leaves a lot to be desired.
Seeing that this weekend is Mothers Day I doubt I'll be doing any trruck work this weekend...
Superlift Blocks
Rear Leaf
Lift Blocks
No experience with them but blocks are basically just spacers... I'd think as long as the bolts are good quality, you're on the way to stardom. :nonod:
No - dont work for Readylift - but i did install the rear block on my truck - and they are taped slightly
the article was copy/pasted from their site - knowing there is alot of confusion for the blocks for the GMT800 to the GMT900 ..
yeah , the advertisement could use more clarity ,,
i just put the ready lift 2.25 leveling kit up front and the blocks yesterday. everything went smooth until i got to bolting the u bolts back on. it seems like the ubolts they supply could be used for a bigger block and the threads are long. it would have been way easier if i actually had an impact gun with a very deep socket. turning a wrench on very long fine threaded u bolts definatly sucks. it rides great though and feels great. can't wait for my new tires to show up
I think you will find that once you remove the factory blocks and measure them, that it is only a 1 inch block and not 1.25 inch. I took my factory blocks out and replaced them with a 2 inch block from Truxxx. It will give you an addtional 1 inch lift in the rear. If you go to Truxxx's website it will not show an option to buy just the rear blocks, but if you call them and tell them you want just the rear blocks, they will sell them to you....and there is a specific part number for them.
Also, the blocks from Superlift require you to stack them on top of your existing factory blocks.....IMO I would not stack blocks, most people advise against it.
Stock '07+ NNBS block vs. ReadyLift Block for reference. Replaced these at the same time I did the leveling kit up front and the truck sits with a slight rake like I wanted. I don't remember what the stock block measured (1" vs. 1.25"), but that's easy for anyone with a ruler to go out and check.
The supplied u-bolts are indeed way way long, and if you don't have air tools, well, GOOD LUCK! Your arms will most likely fall off using a socket wrench.
hell i didn't have a socket deep enough so i had to use a wrench, and yes my brother in laws and my arms just about fell off. just got my tires on today (285/70r17 terra grapplers). love the way it looks.
  • 1 year later...
  • 2 months later...
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
