Currently have a 2000 silverado 1500 5.3L V8
I want to lift it and was thinking of a 6inch Rough Country Lift, with this would I need a leveling kit? Im just not really sure what it all in tales, my first truck and want to do it right.
So any help is greatly appreciated! thank you alex
I can't really help out much as far as what manufacturer to go with but... the leveling kit is only necessary if you want to raise the front end so the truck sits level. Lift kit of your description a leveling kit is not needed.
was looking at their site and they have 2 6in lifts
6" suspension lift kit or 6" NTD suspension lift kit
not really sure the difference is and what it means
ok so then I could level it and then lift it 6in?
One is "non torsion drop suspension". still unsure what that means.
If you are going to lift it 6", there is no need to put in a leveling kit. A lift kit has many more parts included and leveling kit parts may get in the way. You either level the front end (lifts front end roughly 1.5") or put in a full blown lift kit.
If your truck is a 4wd, then the difference between the kits would ultimately be ground clearance. The standard kit will drop the torsion bars around 6". The NTD kit will keep the torsion bars in their factory location, and this is done in part to achieve greater ground clearance. As far as leveling the truck goes...you don't need to. Most suspension lifts are designed to level the truck..ie, the front will be lifted 6" and the rear 4".
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 966 Guests (See full list)
