2009 Speaker Upgrade
I have an '09 Silverado, extended cab, with factory non-Bose radio. I'd like to replace the speakers with something a bit better.....these sound kinda blah, or drab to me.
What will fit in the front and rear doors?
Any recommendations?
Thanks!
Depends on your flavor! 6 1/2" will fit in the font and rear doors but others have done different sizes depending on what Modifications/Fab work you want to do!
Thanks....I'm not looking to do any fab or mods to the door panels at this time. I just want a direct replacement for the stock speakers.
2 ohm, 6.5 inch
Okay.....I'm thinking of two sets of Infinity Reference 60221
I'd leave the tweeters in the pillars alone.....will this be a good improvement over the stock speakers?
I know that changing the head unit would be a good upgrade too....but for now....I'm just doing speakers until I decide what I want to replace the HU with.
Thanks!
I replaced my front speakers and tweeters without amping. I soon realized I wasn't going to be happy until I added an amp. So, I then put in an Alpine amp to push the Polk component set I had installed and it was a DRAMATIC difference. You will hear some difference, mainly in volume, but you will get distortion pretty quickly because that HU can't push enough to the speakers. If I was looking to replace all four speakers, I would spend a little more and just replace the fronts and add an amp. Then, I would add the rears later. Just my opinion.
Thanks!
This is exactly what I did. And I did not replace the head unit. It is a definite improvement over stock!
rbiggers......any install issues? I guess I just gotta figure out how to pop off the door panels. According to Crutchfield, the rear speakers need some kind of bracket or spacer to make them fit?
I found the speakers online for $50/pair.....so for $100, it seems like a good upgrade.
Thanks...
+1. You will notice some difference with just the speakers, but adding a amp is huge!
Hey NoLuck7 What Polk's did you go with??
If you go the route of only adding fronts and amping, buy a four channel amp, so when you do up grade the rear you wont have a buy another amp for the rears, all you will have to do is wire them up.
I went with the DB6501 series. I have been real pleased with them. The jump from stock to nice speakers was decent, but wow, the difference when adding the amp was enormous! And, I did use a four channel for the very reason of adding rears later. Good call on that one Z71Kris.
Great point there, that's what I did when I did my first upgrade. Saves money and hassle in the long run...
I still have some of the old DX series Polks, awesome speakers but I think it's time to retire them. I've been debating between the DB or the MM series, I've only been able to listen to them side by side in Fry's. The setup in the store is crappy to say the least, so I can't tell how much difference there truly is between the two. What kind of wattage you pushing to them?
ok, ok....I get it. I should add an amp too. Now, it's been a long time since I have added an amp to a car system. So please bear with all my questions....
is it easy enough to add an amp to the stock HU?
Where are you guys hiding the amp?
I'm sure there will be more Q's to follow.
Thanks!
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
