Road Sensing Suspension
it senses the road, and tells it nice things so your vehicle rides smooth.. :sigh:
really though...... what mike said :D
Thanks!! One more question, I ordered a navigation system and I need to install the GPS antenna. Should I get the dealer to install this or can I do it myself?
if you take your time, you can do it...the GPS antenna usually goes under the dash behind the radio close to the ambient light sensor
come to think of it, your dealer may only need to reprogram the nav unit to reflect the correct VIN number....remember, these GMT900 trucks use the GMLAN system for "total vehicle integration"...
Wtf!? You have an escalade man! You're ballin' out of control. Pay someone to do the shit. :sigh:
Wtf!? You have an escalade man! You're ballin' out of control. Have daddy pay someone to do the shit. :sigh:
Fixed. :D
Ok....where's Tobias? :devil:
Fixed. :D
Ok....where's Tobias? :tear:
Burying his wallet. :devil:
Fixed. :D
While you've got the hole, throw your wife's purse in there.
Wtf!? You have an escalade man! You're ballin' out of control. Have daddy pay someone to do the shit. :dunno:
Fixed. :D
Ok....where's Tobias? :P
Burying his wallet. :D
Why stop there? Throw the wife in there too :P
Seriously though, you should be able to install the GPS antenna yourself. Assuming it's like the other GMT900s, you just have to pry up the panel on top of the dash where the defroster vent and headlight sensor are and snake it into the right spot. Wear gloves so you don't scrape up your hands, but past that it's not too difficult.
Wtf!? You have an escalade man! You're ballin' out of control. Have daddy pay someone to do the shit. :D
Fixed. :D
:P:P:lol::lol::dunno::D:D
Do you have any more links on how to do this?
