Bad Gas In Nw Florida?
For the last 3 weeks I have had my truck at the local dealership due to a hard starting issue in the morning. After letting the truck sit overnight, I would go to start it up in the morning and it would shake,shutter and stall. Then it will crank up fine. The dealer had me bring it in and we let it sit overnight. The next morning same thing. They ran several tests and consulted with GM and they all agreed it was the MAF. Well I went in this morning to have them replace the MAF and they had 9 other vehicles with the same problem. Several GMC's with the 6.2 and several cadillac CTS's and DTS's. My service advisor and head technician pulled me aside and asked me what gas I use. I told them 93 octane and I fill up at SAMS club. They suggested that there was a shipment of bad gas that is causing this issue. Has anyone else experienced this in other areas of the U.S. ? Thanks Ryan.
I have not, but a few months ago there were something like 6 or 7 different fuel stations affected. I guess what happened is that the tank farm where all the fuel from the local refineries goes to, had a build up of sludge in one of the main tanks. When the operator switched the tank over to the specific gas types, 76, Shell, BP that sludge then went to each of those tanks. So all the different brands were affected at once and it screwed up a few engines. Last I knew, the tank farm was paying all the damages and replacing the bad fuel that people got.
I have had that happen before, on several occassions. I am in doubt of the 'bad gas' theory, unless you consider ethanol bad.
My 00 Suburban hates anything ethanol. it is worse when they either just get a shipment of fuel or just before they get the shipment.
The best cure, I have found, Seafoam the truck, change fuel filter, and keep good non ethanol gas in it.
Any outboard owners will agree...
My engine is a 6.2 Flex fuel vehicle. I would hope that it would be able to handle any ethanol up to the 85% blend. I do agree with the seafoam. I have used it in a couple of my boat engines. :D
    HWN808
    HWN808
  • Who's Online   4 Members, 0 Anonymous, 930 Guests (See full list)
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
