Got The Bull Bar...now Need Some Lights To Go With It!
Which lights???
25 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hello everyone! I have been lurking around for the last couple of months so I figured it was about time I posted something!
I own a 2009 GMC Sierra Crew Cab 4x4 "White Diamond Edition"
I bought a chrome bull bar, but now I am not sure what kind of lights I should get for it. I know I want a "long range" light rather then a "fog" or "driving" light.
I was looking at these ones online:
KC Hilites
And these ones as well:
PIAA
Any recommendations from anyone? I want to keep it around the 6" diameter ones because I am pretty sure the 8" ones won't fit on the bar properly.
Thanks!
KC Hilites
PIAA
Thanks!
From what you linked to,
The KC are 130 watt bulbs, and the name says they are long range. The PIAA are 85 watt bulbs, fog/driving. You said you would prefer to get a long range, I vote the KC lights. I also find the KC lights more aesthetically appealing.
I have the KC slimlights 6". anything bigger than that will not fit a bull bar without pointing at the ground. I have the long range ones they're awsome. Hope this helps
I have five KC 130 watt Daylighter slim lights, and they are an awesome light performance wise. I also have 6 PIAA 520 series yellow ion driving lights on my Silverado, I like the look of the PIAA's better. But the KC lights are much brighter for sure, but the wiring for the PIAA is very nice and complete plug and play. It's up to you, but either choice is a good choice.
Great looking truck, we have one other White diamond truck member here too :cool:
Welcome to the site!
LIGHTFORCE. one of the few that can servive a shot gun blast and can get hit with anything else you can through it's way. plus they are bright as hell worth the price
Edit: oh ya and the beam patter is adjustable
I voted for the KC's, the 130 watts should be more than enough for you, I have the ones that carquest sells and those are a 100watts a piece, I have 4 of them on my big truck and what a difference, I will take some pics tonight when I leave for work and post them when I get home of the difference they make, but the ones at car quest are like $20 per bulb, and then you got to buy the housings for them, they make them in chrome and rubber, if your interested I will get the part number for the bulbs its either 3907 or 5907 not sure right now... Lucky for me I get the company discount on them for my personal use and they are like $10-$13 a bulb in my area so if you have a buddy that gets a discount at carquest you cant really go wrong IMO, those prices might be different where your located
EDIT: These lights are 4 inch too by the way
I didnt get any pictures, I couldnt figure out how to shut my flash off on my camera... but the correct bulb number is carquest/wagner 4509 if your interested
+2 for the lightforces. Light weight. Bright as all hell. and you can change them up from flood to spot just like a mag light. Ive got several sets of colored filters on mine depending on what kind of conditions im driving in.
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
