Gmc Sierra Denali Moldings
I have 4 used door moldings from a 07 Sierra Denali nbs. They are oem summit white with the chrome strip at the top. I'm selling them because I'm upgrading to escalade moldings. They cost $300 at the dealer just for the molding plus $100 to have them paint to match so I know what I have. The only thing you would have to do is put double-sided tape on the back, but you can easily go to autozone or pepboys and put it on yourself or go to a shop and have them put them on for you, your choice. Im asking $250 obo. If interested pm me. Thanks
