To Turn Or Not To Turn...
Some say always, some say only if there was damage to the rotor(s) and some say they don't do a complete turn on them but use the roughing pads to prep the surface.
What do you do?
I'm not a fan of turning rotors, unless is a very small amount. Usually after having them turned, the first time you heat them up good is they warp. :rollin:
Thats been my experience over the years. Not a fan!
Unless the rotors are out of spec, I dont touch them. If, I replace them. I want as much metal as possible on them.
I've turned a lot of rotors in my days at the shop and have never had one person come back due to warping... however, I only turn rotors that are still well above spec after they have been turned.
At a minimum, i would scuff them up to eliminate any pre-existing grooves from the old pads... if you just toss pads on, your likely to develop squeaks.
I agree....you do need to cut through the glaze that was created by the old pads....a good scuffing is all that is needed.
I only turn the rotors if the brake pedal is pulsing while braking, due to warping. Often, they are out of spec at that point and usually I wind up replacing them at that point.
I suspect GM says not to turn them to reduce costs, and sometimes that can create problems, if not done right. It also reduces thickness, which is some times a problem - requiring rotor replacement.
Rotors rarely, if ever "warp" - see this article from StopTech.
I never turn my rotors - I install new pads, properly bed them in, and go on. If there is a problem with them, I replace them.
    ar0517
    ar0517
  • Who's Online   6 Members, 1 Anonymous, 527 Guests (See full list)
