P0300
mstafford
I have a 2000 silverado Z71 4x4 with the 4800 and a 5 spd. It has around 116,000 mi.
The "service engine soon" light comes on when the rpms are high (like over 2,000). So basically at highway speeds or high revs, the light comes on.
I used a diagnostic tool, and the error code read "P0300", which is random/multiple cylinder misfire. I changed the spark plugs, but that didn't do it.
any help as to what it could be? Thanks...
Check at the following link...
http://www.random-misfire.com
Then also someone else just had a similar problem and it turned out to be a faulty camshaft position sensor. Other people have just replaced spark plug wires and that did the trick. So just got to check all sorts of things!
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
