Idler Arm Replacement Question
I need to replace my idler arm on my 2500hd. Anyone know if how hard it is to do on this truck? And also do i need to replace the bracket assembly as well? Thanks
i think i depends on were the wear is but i think the majority of the wear will be in the bracket assembly depending on how often it was greased .they usually miss it .
Any idea on the difficulty or accessability?
Just replaced the idler bracketr, idler arm and pitman. Very freaking easy with a kick azz Snap on imapct.
How long did it take you to replace? Did you use a regular 2 jaw puller? How much did the parts cost? Sorry im out of work with a back injury so im broke and pretty immobile so im just trying to see if its something i can tackle on my own without killing myself ya know? thanks
Will give you full update tommorw sometime on everything.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
