Wet Okole Or Coverking?
Ok guys... I am a teacher and so i spend a lot of time at the lake in the summer.
I want a seat cover to protect my seats that DOESN'T look like a seatcover.
(not to mention from the abuse my 1 yr old daughter who will be riding in back may impose!)
In my Tacoma I currently have Wet Okoles.
Anyone have an opinion on Coverkings or experiance with both brands>????
Let see some pics!!!!!!!!!! Attached are my WO's
I had Wet Okoles in the truck but I had to take them out since they smelled like smoke (bought them used over the internet) but the fit and protection were top notch....
I went down to the Newport, CA Wet Okole store and looked them over and talked with them a while. My only heartburn with Wet Okole covers was their insistance that they not be washed. I wanted a machine washable cover.
I bought some velour rear seat covers from Cover King. The rear seat alone was a couple hundred bucks. They don't fit as well as I expected. But my rear seat is the complex LTZ 70/30 split bench with the center pull-out rest. The armrest area is the worst fitting part.
Chuck
Chuck
?? I threw my old ones into the washer (on gentle cycle) several times to get rid of the smoke smell and there was no apparent damage, though the smoke smell still lingered.
I dunno, Mike. I asked about washing after I read their brochure where it mentions cleaning and they were emphatic that they not be washed by either machine or hand washed in a tub. That was my only problem with them and they convinced me not to buy their covers.
Got pics of your cover king?
I'll try to shoot some pics later of the rear seat Coverking details where I think it's a bit half baked.
Go with the Coverking covers. Had them in the Grand Am for over a year and had no trouble with them. The Wet Okoles I had before, I had to vent the car out a few days to get the smell of lake water out.
You must have a stinky lake... Mine never do that! j/k
I Would love to see pics guys!!!! I am leaning towards WO just because that is what i know!
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
