Any No-drone Exhaust?
Is there any catback or muffler's for the trucks that don't drone on the highway? i'd like one that has some bark when you go WOT but little to NOTHING at cruise. Just seeing what my options are:)
Only reason i ask is i like the sound of the Flowmaster that i had on my '00 4.8 Silverado and loved it when on the gas but hated the drone at cruise
Do they make a single IN dual OUT muffler? idk if i want to Y off after the cats and throw 2 under there. If i have to then that's fine but would rather not
Sounds like Corsa has the popular vote but I thought I also read where Magnaflow was also really good. If I remember correctly it is also a hell of alot cheaper.
The Flowmaster 70 Big Block II drones a LITTLE, but it is more than tolerable. Now, the FM 50? :P
Corsa FTW !
Didn't like the exhaust tips, they looked like goofy trumpets. :P Replaced them with straight Magnaflows tips. Much more better.
originally put a Flowmaster Big Block 50 series on my 6.0 HD...was on for over a year, and I never was happy with it. It had a raspy cackling sound and some interior resonance, but not too bad.....
Last week I had a Magnaflow installed and really like it. I went with the 26" or 28" longer version of the magnaflow, as it is supposed to be quieter.
The first few days I was upset because it was too dammm quiet....I could only hear the exhaust at 3500 rpm...
Well, after a few hundred miles it opened up some, and now it sounds really good...not loud, but healthy. At 3500 rpms it really sounds great.
It has a much softer rumble than the flowmaster and more of the traditional small block chevy sound.
On my particular truck, there is absolutely no resonoance in the cab....in fact, when it shifts into overdrive at less than 55 mph, it can't be heard.
My son loves the sound and the rumble, so he ordered a magnaflow for his 8.1 big block...he got the shorter one for more noise, but the non-cackling flowmaster sound....we'll see about the resonance.
i had the same concerns as you...I went with a 24 inch long magnaflow muffler and I hardly notice it at highway speeds but it sounds great when you stomp on it
I had a Magnaflow Catback and really liked the way it sounded. It did get a tad too loud and had highway drone when I started to put engine mods on, so I switched to a Corsa Touring.
I completely agree. I went with the magnaflow which was a compromise between price and highway drone. You definitely notice the drone especially at highway speeds going uphill. But the price was right, $405 including shipping from performancepeddler.com (that was for the single-in dual rear exit). The magnaflow sounds awesome on the street, but if you are looking for absolutely zero highway noise you will not be satisfied. I do not mind it at all, you can still listen to the radio and carry on a conversation without having to raise your voice but you can hear it. Magnaflow imo is better than flowmaster for highway noise, but if your want the best you will have to pay for the best and get the corsa.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
    • PCM?  These don't have a "PCM".  Powertrain Control Module.  They have an ECM (Engine Control Module) and TCM (Transmission Control Module).   Do you mean update the radio?     You can check what version you have in the settings page.  Should be Y181 but there might be a newer build they can update it to.
