Removing Front Brake Rotor On 2006 Silverado
Trying to replace front brake rotor on a 2006 Chevy Silverado 1500. The rotors are frozen (rusted) on and I cannot pop them loose. Sprayed some penetrating lubricant and beat with hammer but no luck. Anyone know what the 3 small threaded holes on the front face of the rotor for? One of these has a torx screw in it. Are these for pulling the rotor off the hub? If so, how? Anyone done this before?
Thanks.
Remove the screw. It is only there to hold the rotor on during manufacturing process.
For those wondering the two threaded holes are for a 3/8-16 (coarse thread) bolt. When threaded into the hole it will hit against the hub and eventually pop the rotor off. Continue to ratchet the bolt until you hear the rust cracking. You will need to brace the rotor with a pry bar wedged into the rotor fins so that it stays stationary while you are cranking the bolt down. Use a grade 5 or SS bolt so that it doesn't gall up or bust the head off because you have to really crank hard on it.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
