Set Up on 07-12 Chevy 1500 with Fisher Plow
MSM1
Guys,
Just wanted to pass this along. I placed a Fisher HT series plow on my 07 Chevy 1500 Ext Cab LTZ pick-up. I have the solid color matched front bumper so in lied the problem of getting the plow wires through. The dealers wanted to take the grille and sandwich the wires for the plow between the grille and the bumper which you and I both know would've chaffed the paint right off
I decided to mount the plow module where the extra battery goes under the hood of the truck and I made a plastic mat that sat exactly in the well of my center console. This is where I stuck the joystick control for ease of operation. I then ran the plow harness wires down toward the front license plate frame. I figured since I had to cut the front valence to mount the plow I might as well cut a whole in the license plate frame and runt he wires through it. When its winter I take the front plate off and run the wires through a oblong horizontal hole I cut with a dremel in the front license plate and when its summer I tuck the wires back in and zip tie them together and then to the frame behind the front bumper.
Hopes this helps anyone who does not want to cut holes in the grille of their truck or ruin their bumper. I spent a lot of time thinking this over and came up with this idea. Its been working out great.
Any questions and Ill send photos
Sounds like you spent some time on it. Post up some photos, I'm sure the plow folks will appreciate them.
I second the request for pics.
Guys,
What did you do about the frt suspension on your truck to handle all that weight hanging out frt?
Guys sorry for the delay. I had been tied up with a promotional exam with work. I will post the pics ASAP. Give me until tomorrow
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 2,066 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
