Headlight Bulb Replacement : How To?
Ok guys.. so My low beams are horrible and want to put in some silverstars and need to know how to replace them.
I have heard you have to take off the whole grill just to replace the bulbs??
I have not yet tried or looked but thought i would ask the experts first.
any help would be great....... :lol:
Are there H11 Silverstars now? Last I knew they weren't made.
I just picked some up at Autozone about 3 weeks ago. I took the last two that they had though. :lol:
  • Replies 35
I've always RAVED that headlight replacement is the ONE thing that's easier on new vehicles than on old ones. I hope GM didn't go and mess that up.
The did mess it up royally on the GMT900's. The old arrangement in the 800 series was beyond simple; pull two pins and pull the entire headlamp assembly forward. Then access to the turn signals and DRL's was pretty easy too with just the one clip.
Whoever did the engineering on the new assemblies should be forced to go around the country and change any bulb that goes out. :lol:
Coming from someone who has family that works for GM, they did it to keep the super tight tolerances that people expect in cars. Now why that carried over to trucks (utility vehicles) I will never know.
And yes, I have bloodied a few knuckles changing bulbs in mine.
Just my opinion, but of all the vehicles I've had, the GMT900 headlights are by far the best beam pattern, even in stock trim. They have amazing beam cutoff at the top to prevent blinding an oncoming driver and excellent control of the other aspects. Very good job on them, IMO.
i agree, and the visibility even with the stock bulbs is excellent. i've had bad luck with Silverstar Ultra's in past vehicles. the bulb life was abysmal and the light output was just alright, IMO. i ran the standard non-ultra Silverstars back in college and they never burnt out. i've decided with my Sierra to save my money and just run the stock bulbs. my truck has plenty of visibility as is.
Has anyone used PIAA's Extreme White Plus bulbs? They're more expensive, but I'm wondering if they're better than the Silverstars.
I used them before I got my HID's and they're real good.
  • 7 months later...
My hands are pretty large and to get the bulb out is going to be really hard. Do I need to unscrew the windshield washer fluid holder to make room? Any tricks? needle nose pliers maybe?
  • 8 months later...
The silverstars carry a one year warranty, keep you receipt and you just go get a new set if they burn out befor the year is up.. i haven't run any in the truck yet, but all my other vehicle have them.
At $80-100 a pair and a realitively painless install, HIDs are the way to go. In Canada my low beams are my daytime running lights and therefore get 160 to 200 hours use each year. That is beyond the average life expectancy of highend halogens every year! @$25 a pop I will stick with my HIDs, My last set in my old Astro lasted seven years and are still running. The new H11 set in my S'10 Silverado will probably last me the same amount of time. Changing the bulbs may be a tight squeeze, but, if you only have to do it occassionally, it will be a time saver.
(also put LEDs in the interior, rear cab lights, license and backup lights)
  • 1 month later...
With all due respect for your family, changing the DRL bulbs is ridiculously hard on a Tahoe. Someone at GM had their head up their cuss when they designed that system. I would have been easy to design in a pop-out plastic plug in the bumper cover to allow access to the third screw instead of dismantling the front end for a little bulb.
Rant over...
It is a mission to replace the headlight bulbs when they go out. I run the Silver Star, they look great but they don't last very long. The longest they've lasted is about a year. Thinking of switching to H.I.D lights on my headlights & fog lights.
  • 1 year later...
I have a 2008 GMC Sierra and recently discovered an easy way to change the passenger side top bulb. I replaced both bulbs last summer, but one bulb already burned out and had to be replaced.
Disconnect the upper half of the air filter housing and move out of the way. You may have to loosen the hose clamp to give you more freedom. The lower half of the air filter housing can easily be removed with a slight upward tug. Once removed you have easy access to at least the top bulb. Swap out the bulb without touching the glass on the bulb. Once changed the lower filter housing can be re-inserted with a slight push back into the same holes and then re-assemble.
Now to figure out the driver's side.
I use to be able to reach my driver side bulbs. Now I have an aux battery so I can't get my hand in there. I did use two sets of 12" medical forceps to replace a driver bulb last week.
The passenger side can be accessed for replacement by simply unplugging the MAF sensor, loosening the connector hose clamp, and removing the entire (upper and lower) air box in one piece. It just pulls out. No need to disassemble the upper from the lower half.
just replaces my highs and lows with piaa xtreme white plus. thought it was easy and simple compared to some peoples complaints.
the lights themselves are pretty good but only had them about 1 1/2 weeks or 2 little blue tint compared to my yellow fog lights
http://i1311.photobucket.com/albums/s680/Cody_Thorson/truck008_zps82be7910.jpg[/img]"]http://truck008_zps82be7910.jpg
Are those H.I.D's in your fogs? If so, you are the only other person with yellow H.I.D's that I have seen :)
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 3,190 Guests (See full list)
    • My 2015 1500 LTZ Silverado suddenly won't go into 4 x 4 low. It will go into 4 x 4 high.
    • Yep, just a quick reference point.    My main point being I’d do a thousand other things before I’d pay 10k for a transmission.    Speaking in ignorance cause I don’t look at these trucks, what is it worth? 20k?
    • I think users are going to want to pick their monitored parameters, which parameters they want to see first.    It should probably start with baseline at a minimum and adjust to learned, but be able to overlay baseline for comparison.   A simple severity level would be able to determine what type of alerting is appropriate or user selectable.    Why not use the OBD port though?   I think a phone connection would be a good idea, push notifications type deal.   Number 1 issue is having data is useless if you don’t know what the data should be under normal conditions.
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Monday looks like a good day for the dealer to test an ac issue. Hopefully it all turns out good.
