TSB 03-06-01-010
srlbotanical
I need the full listing of this TSB if anyone has it.
Thanks!
Steve
Subject: Engine Oil or Coolant Leak (Install New Intake Manifold Gasket) #03-06-01-010B - (10/24/2003)
Models: 2000-2003 Buick Century
2002-2003 Buick Rendezvous
1996 Chevrolet Lumina APV
1997-2003 Chevrolet Venture
1999-2001 Chevrolet Lumina
1999-2003 Chevrolet Malibu, Monte Carlo
2000-2003 Chevrolet Impala
1996-2003 Oldsmobile Silhouette
1999 Oldsmobile Cutlass
1999-2003 Oldsmobile Alero
1996-1999 Pontiac Trans Sport
1999-2003 Pontiac Grand Am, Montana
2000-2003 Pontiac Grand Prix
2001-2003 Pontiac Aztek
with 3.1L or 3.4L V-6 Engine (VINs J, E - RPOs LG8, LA1)
This bulletin is being revised to change the model Information. Please discard Corporate Bulletin Number 03-06-01-010A (Section 06 - Engine).
Condition
Some owners may comment on an apparent oil or coolant leak. Additionally, the comments may range from spots on the driveway to having to add fluids.
Cause
Intake manifold may be leaking allowing coolant, oil or both to leak from the engine.
Correction
Install a new design intake manifold gasket. The material used in the gasket has been changed in order to improve the sealing qualities of the gasket. When replacing the gasket, the intake manifold bolts must also be replaced and torqued to a revised specification. The new bolts will come with a pre-applied threadlocker on them.
Notice: An oil leak may result if the vertical bolts are not tightened before the diagonal bolts.
Diagonal bolts may require a crows foot to tighten.
Tighten the vertical lower intake manifold bolts (1) to 7N·m (62 lb in).
Tighten the diagonal lower intake manifold bolts (2) to 7N·m(62 lb in).
Tighten the vertical lower intake manifold bolts (1) to 13N·m(115 lb in).
Tighten the diagonal lower intake manifold bolts (2) to 25N·m(18 lb ft).
Parts Information
Part Number Description Qty
89017279 Intake manifold Gasket 1
11588915 Intake manifold bolt - short 4
11588914 Intake manifold bolt - long 4
Parts are currently available from GMSPO.
Dang that is great info. man! I don't own one of the covered veichles but that was really nice of you to go through the trouble of posting the image as well. That's pretty d@mn nice man! :sigh:
    • What meaningful corrections were done to fix the "machining errors?"   I bet nothing, because the 6.2 is soon to be obsolete. Why would GM implement any fix let alone an "expensive one?"   Until someone can provide any convincing information that GM did ANYTHING to correct the engines - the 6.2 is no for me.    Which means keeping the 2016 Denali longer until the next generation (6.6?) proves itself.
    • If my father took a Sunday off. We did the Sunday drive. Usually stopping at a Geno’s for dinner that we eat in the car. Six of us with my little sister up front. It was always a Buick growing up. In New Jersey you couldn’t get lost. Not like Texas.
    • Hoooooooly smokes, batman!
    • I suppose I am Atlas. It can always be worse, eh?   I had a friend once that rolled one payment into another until he was paying the price of Benz for a 10 year old back marker. Wouldn't be often you start a new payment the month following your old one.
    • I still enjoy the drive   Some people fish when they retire; some golf. I drive. We've lived in the same general area now for twenty eight years and I'm still finding at least monthly some sweet quite little road to explore. When I tell the Mrs. I'm heading out for coffee she knows that could be a five hour event. Often she even goes along.    I like finding new rural routes used mainly by the locals that start nowhere in particular and end the same way. Many in the area of that type are narrow paved and twisty, hilly and run through field and timber. Often along creeks or wetlands. Unfarmable areas of great natural beauty.    After years of this type of exploration they start to fit together. One ending a mile or so from another and you start threading together a new path from a unfamiliar place to a new adventure. Sometimes to a little town of under five hundred that used to be something before the Interstate or some railroad or US highway bled the life out of it that has a small dinner with the greatest slice of pie you've eaten since grandma made her last. A little village museum or library or even a town square park with grand old oak, walnut and Osage orange trees to sit under while you sip you gas station coffee and chat up some locals.    Often they are full of stories about the main streets more interesting buildings and the who's who of the area. Sometimes some hidden attraction or unseen history. Our area is full of old coal mines.     A younger self used to do this going cross country by motorcycle. Only a general area as a destination with no time to get there and no time to be back. Sitting at days end in a 10 unit off the main highway motel under a Sycamore tree yacking with the owner or his one semipermanent guest while I adjusted valves or the chain. Always a wave and a shout "Hey there stranger"!  It's how I came by my love of old Brit iron. There is no such things as a ten minute gas stop when your on a Enfield or a vintage Triumph. Same being true of old cars.    If you take the time to really look I've found everywhere is someplace interesting. Illinois or West Virginia. Different and yet the same.    People are in a more relaxed mood and will talk about anything and everything and if they like you there may be a cupp'a or a lemonade and a sandwich in it. 😉
