Silverstar beams & 4 high kit
Is the Silverstar beams a HID kit or just replacement bulbs? Also, does anyone know of a supply for the 4 high kit, or is there instructions for enabling 4 high (instructions would be perfered).
Thanks,
Chris
Silverstars are just a bulb upgrade.  Cost is about 20 bucks a piece and they make your headlights look similar to the HID's.
Check out
SUV LIGHTS
They sell a kit to convert to 4 High.....
they have the same lumen output...just a different kelvin temp color
I put the SilverStar lights in my truck and they made a world of difference I can see now. They are well worth the 80 bucks for the set. I also rewired for 4 lights on with bright. I can light up the world now. I used a diode but am thinking I will set a relay as my dims get a touch dimmer when I hit the brights. For the money go with the SilverStars.
The SilverStars are "just" a bulb replacement, but the difference in the color and (perceived) intensity of the lights is really quite noticeable. Certainly worth the money.
www.stylinconcepts.com has a relay that you can get for about $20 which allow the highs and lows to be on simultaneously. That's what I got, and with better bulbs the difference is like night and day! :thumbs::D (pun intended)
For what it's worth.........
There are a lot of ways to gain the 4 High look, however if you go with a upgraded wiring harnes like the one provided by SUV lights you take the load off the switch and put it where it should be (In the relays) And you also upgrade to larger wires meaning more power to the lights and more power means a brighter light that is operating under the conditions it likes.
The was these harnesses work is you turn the switch in the dash or the DRL;s turn the lights on and then the relay draws power directly from the batery and sends it to your lights. The factory way is to draw current through the swith, thus creating some heat transfer to your dash and over time blowing the switch in your dash. My parents have a 93 GMC that has this exact problem.... Changed out the switch and threw down the 30 bucks for the harness and walla the lights are brighter and no draw thru the switch as read by my fluke meter. Doesn't matter who you go with as far as the harness just stay away from adding extra draw through the switch :thumbs:
:D
www.kennedydiesel.com sells the above mentioned light harness that uses relays and takes the headlight voltage right off of the alternator. Not only will the Silverstars be brighter than normal, they will be even brighter with direct alternator voltage.
My wifes van has Silverstars and it made a big diff, if Im ever in town long enough my truck will get them too!
*EDITED FOR SPELLING*
Go with the suvlights linked above. It will save you some cash and give you the same result as kennedy diesel. KD's kit is about 60 bucs there kit is about 30.
:thumbs::D
The Kennedy Diesel kit is $135. Thats just the wiring harness - no bulbs. The deluxe kit with bulbs is $205. They sure are proud of their stuff.
walmart has the Silverstars(2 in the pack) for 26.9
Edit: I might grab a set but do these give that Blue look? Curious becasue In the snow Ive notced the whiter light makes it harder to see than regular halogens. Im not the only one thats noticed this.
Also have you ever driven alongside a BMW or lexus with the HID type bulbs? Im not sure those lights lght up the road any better when its pitch black out. They are "brighter" but when you look in front of the vehicles everyone Ive talked to say they cant see the road as well under any condition, and especially if its snowing.
......In the snow Ive notced the whiter light makes it harder to see than regular halogens. Im not the only one thats noticed this.
No snow down here on the Texas Coastal Plains, but we have chronic high humidity resulting in haze. These Silverstars, for my eyes, do not cut through this haze at night making it more difficult to see, either on highs (when needed) or lows.
Definitely need a warmer bulb in these conditions. Not sure what bulb ratings I have for my OEM lamps, other than the fact that they are Philips brand. Going to their site reveals nothing. But for me, the OEM bulbs in this '03 truck are brighter than the Silverstars. This is totally different than what I have seen with '02 models and earlier in which the Silverstars definitely appeared to be brighter, albeit having the expected bluish-whilte light.
I haven't seen as well athnight since the Lasik surgery on my eyes. The Silverstar low beams made a big difference for me. I think the beam is wider and brighter.
only downside... the guy comming toward you hates it.
Silverstars and Kennedy harness are incredible!
Yes that harness is more expensive, but one of my troops has a harness that looks similar to the link provided and its crap. If you look at it funny the conections pull apart.
Kennedy's stuff is all soldered and waterproof. I guess you get what you pay for.
    • No I didn’t watch a video of a person who analyzes oil for a living explain general oil usage. For clarity I did ask my brothers one who runs our equipment business. The other who runs our old ROW business about oil usage. Nothing has changed since I retired. Their personal vehicles or work vehicles use no oil. Not enough to see on the oil checking device. Then I pondered. I like to ponder. In this extended oil changing world with oil change countdowns or lights. If engines used say a qt every 2500 miles or up to even 4000 miles. With oil changes reaching as high as 15000 miles. Normal for most people is eight to ten. Vehicles should potentially be seizing up all over the place. Especially in hilly terrain. Just how many people actually check their oil? Maybe 10 percent. Those are the people that probably change their oil early. I like to research used car listings. I have five favorite dealers I check. They all list carfax with their listing. It’s rare to see vehicles with anything but extended oil changes. Transmission service, forget about it. I’ve seen Honda and Toyota certified vehicles up to 100K miles and ten years old. With nothing but normal maintenance. Isn’t nice we all have different experiences and believe our way is the best. You certainly get backup for whatever you believe. Life would be boring otherwise.
    • Interesting rumor. Dealers near me have been tight-lipped so far, but if this reveal actually happens next week, I'm really hoping they finally give the HD a proper interior overhaul. The competition has been eating their lunch in the cabin department for a while now.
    • There are a few good takeaways in that video that pertain to this thread, certainly the possibility of the oil control rings having buildup, the fuel injectors and how clean or not that they are ending up affecting the pistons rings carbon buildup, and the fact that its normal up to a point for a given engine to use some oil, and that the oil quality that is being utilized is part of that ring clogging up issue as well.   I was talking with a neighbor yesterday who has a baby LZ0 duramax and he had bought it slightly used but it does consume some oil and he has switched over to 5W-30 Euro spec oil and in this case that never made a difference in consumption over the factory 0W-20 recommendation. He finds it uses a quart in about 3500 miles and as he goes a ways over that distance he adds oil to full and goes another 1000 miles or so and then changes oil and is typically at 40% or so left on the oil monitor at that point with his use case of quite a lot of highway miles and more limited in short run use. I don't know what other LZ0 engines are doing for oil consumption but that is what his is doing.
    • I dont care what Lake says. Goodnight.
    • Ok well I guess Lake disagrees with me on a few points. I call oil consumption pretty basic. Rudimentary. He calls it "really complicated." I think 1qt consumed in 3k miles is a lot. He says that's normal. In 22 minutes, he'll use his natural talent to explain oil consumption to anyone watching this video. He covers everything from obvious engine damage to how normally functioning healthy engines consume oil by design. Lake explicitly states how you drive will impact oil consumption.   Shut up and watch:
