Need Some One Has 07 Yukon Denali
hi
My 07 yukon Denali is now in for its sixth major service repair. One of the major issues is the symptom of depressing the gas to modestly accelerate and the engine RPM's ACTUALLY DECREASE!!!! Yes, pressing on the gas causes the engine to slow down. You can hear the motor bog and see the tach drop about 300 to 400 RPM's. To make this TURD move you absolutely have to STOMP on the gas and hope the transmission finds the right gear. My transmission will upshift and downshift rapidly searching for a correct gear to use. Meanwhile, nothing is happening in the speed department.
and all i get get from dealler "your vehicle is operating within normal parameters"
what about yours ?
Not mine.
Only complaints are the 2 to 3 shift, where it feels like it falls on it's face
A-Post wind and wind noise
But the fly-by-wire go pedal is coupled to the "go" just fine, I can feather it at idle or cruise with no issues.
I must have one that is screwed up since it doesn't act like your's which is supposed to be the norm according to your dealer.
see another dealer
i dont have any problems with my 07 denali .. i do notice sometimes that the tranny shifts a little funny , but thats it
what other issues are you having
hi
what about yours ?
Skytop1?? Ha, Busted!!!!
I have an '07 Yukon Denali "shorty" version. I have never had the engine lose RPM when shifting while gas is depressed. It will ususally downshift instantly to a lower gear to get the rpm's up and then it takes off like a rocket. The only wierd thing I have noticed is when the truck is first started in the morning, once and a while it will read "low fuel". Ten minutes later it will be back to reading normal, half tank left, etc...
The driver's side wiper blade clicks against the windshield when in use. What I did was take it off and used a mill file to remove some of the plastic tab on the end of the wiper. Still looks stock and no clicking anymore.
The driver's door has a very quiet but annoying rattle to it, can't figure it out yet so I just turn to music up. Broke 10K on it last week while on vacation and have had no problems with it. Knock on wood.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
