Getting Clunking Sound After A Stop
after i stop at a red light or a stop sign then let off the brake, i get a clunking sound coming from the rear is it the brakes it happens when i let go of the brake and hit the gas.
Is this on your '96? Is that the only time it does it?
Couple things come to mind. GM's slip yoke causing the driveline clunk or u-joints.
Repack the slip yoke with grease, and inspect the u-joints while you have the driveshaft down and see if the noise goes away.
its a 96 sierra 5.0l only happens after a stop,when i come to a complete stop then let off the brake and go back on the gas thats when i get a clunk sound thats the only time it dose it thats why i thought it may be the rear brakes
Can you duplicate it again by just applying the brakes and then releasing again, without the vehicle moving?
So far the things I would check would be:
Slip yoke/spline for proper lubrication.
Drive shaft u joints and carrier bearing.
The differential for excessive play
Brake shoes and drums
the last owners son blow the drive shaft so they had to replace it with a uesed one and the rear brakes were making noise before but it went away thinking the problem fixed its self maybe not.
Not sure if this would be related or not, but my 01 was doing the same thing, BUT it also would clunk when going over small bumps or speed bumps, etc. So I assumed it was the suspension. I took it to the Chevy dealer and they said it was most likely the slip yoke. They called me and said that my rear end was shot. The pinion bearings and gears and all needed to be replaced. It was like a $2800 repair. :thumbs: Luckily it was all covered by my extended warranty. :(
:( $2800... You can have it done for $1200 pretty easy if you shop around... but I guess thats a non-point because of your warranty.
Glad to hear you found the problem. :thumbs:
My truck does the same thing. I have heard it since i got it (have only put 500 miles on it, has 35,500 on it). I only notice also while at a stop sign and then taking off. It happens mostly when the front end is pointing downhill some and does it exactly from when my foot is in between the brake and gas pedal. So pretty quickly after I let off the brake.
I am going to take it to the dealer when it gets close to 36,000 for an oil change (going to go with Mobil 1 synthetic). Then I will ask them about the clunk and see what they say and have them take a look while its up on the hoist. If anyone figures it out before hand I will tackle it myself if not I will see what they think and let you know if it fixes it. I hope its not my rear end needing anything, that would be terrible with the amount of miles I have on it!
Btw, its a 2003 regular cab short box, Z-71
Ryan
  • 1 month later...
I have an 02 Suburban K2500 with the same problem. I assumed it was the brakes or suspension. Has anyone found a definitive answer to this problem? Mine only does it on hard stops when there is sufficient weight shift after stopping.
there are 2 different types of trucks goin on here ,It should confuse everyone lol
did you find your problem classicxl???
the other guys had the ol' splines dry concern.
    250.3k
    user087
    user087
  • Who's Online   1 Member, 0 Anonymous, 733 Guests (See full list)
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
