Part Numbers For '07-'09 Skid Plates?
Have a 3500 dually and need some protection under there. Does anyone have the part numbers for the two skid plates (engine/trans -not the radiator plate)? Not having any luck searching the OEM parts sources. Thanks.
4WD? CC? New or Old style?
2007+, so new style. CC. 4WD. Thanks.
2007 K3 4wd CC..
skid plate xfer case...15707630
mounting bolt 11518341 x 4
http://www.compnine.com/index.php?u=1&...amp;grouptype=B
Skid plate oil pan 10365308
mounting bolts 11518341 x 2 and 11518341 x 2
washers 11589145 x 2
I posted the diagrams and info for you to double check.
When you order the skid plate oil pan it comes with 2 bolts and the 2 washers. You will just need to order 2 bolts and not 4 for this plate. the holes in the cross members are also already tapped. May have to run a tap to clean the threads due to the factory coating on the frame.
I'm not sure if any bolts come with the plate for the transfer case, I could not find that part number until I came across this thread.
Ended up ordering the set from the dealer yesterday. Can't remember what it cost, but it was a package deal. Took the parts guy hours to actually find it. Once I get it, if it has a package part number, I'll be sure to post it up.
Dealership called and said my "shield" was in. Not "shields", but "shield". Well its an hour over there, so I asked what part number it was. They gave 12496035. Humm, seems that's for 2001-2007. I told the guy it was a new body style 2007.5 when I called to order in the beginning. Damn.
