Truck Won't Run Right.
wagonproject
My 1996 silverado (305) was in storage for 10 years. I got it out this spring and replaced the gastank, fuel pump, fuel filter, spider injector, plugs, wires, cap, and rotor. It ran great for 2-3 months and just the other day I was driving it and felt like it was hesitating. When I start it now it runs rough and when you give it gas it runs rough. You can go a few feet and sometimes it will shut off. I took a friends cheapo scanner and ran it and got these codes.
P0102
MAF or VAF
Circuit low input
02 sensor heater
Circuit malfunction
(Bank 1 sensor 3)
P0300
Random multiple
Cylinder misfire detected
P0420
Catalyst efficiency
Below threshold
Bank 1
Now after I read those codes I cleared it and ran it again and got only the P0300 again. So it must have to run for a while before it throws the other codes?
I took it to a local shop he said it needed a tune up and even then he wasn't sure if it would run without more things. So I just brought it home. He did say it needed a new cap as the one I just put on was sparking on the outside. He told me to go buy a NAPA cap. So I am going to go buy one tomorrow.
Any ideas on what else to check?
P0102
MAF or VAF
Circuit low input
02 sensor heater
Circuit malfunction
(Bank 1 sensor 3)
P0300
Random multiple
P0420
Catalyst efficiency
Below threshold
Bank 1
If it's been sitting for 10 years, then you probably need to clean the throttle body and check wires for mouse chew marks.
I agree that you should get a new dist cap (if someone has reported arcing around the cap)... you could get a NAPA, or an ACDelco would be the best..
AND also....
- does it start cold ok, and then run like crap after it warms up...?
... if so.. I would check the CTS (coolant temperature sensor) on top front of the engine beside the thermostat
.. this sends a control signal to the Powertrain Control Module (PCM) to regulate the fuel mix depending on the engine temp... when they fail, they just keep pumping the rich fuel mixture to the injectors (as if the engine was still cold)
.. cheap part, easy to check, easy to replace if necessary, ... much grief if not working properly
Put a new cap/rotor on. Runs better but still not 100%. And no, it acts up right away. But ill check that part.
Thinking it may have to do with the cat or some sensor according to the codes.
Still trying to get this truck going. Got to move it out of the shop now.
The MAF sensor is broke also. The piece that the wire plugs in to on the MAF sensor is broke so the connector is held in with a ziptie. Seems to screw up the motor as its not getting a constant feed all the time. Any recommendations on where to pick up a good one at?
If I put a new 02 sensor on (the 3 one, the one after the cat) will it do any good if the cat is still bad?
... here's another thought ... I know you said you replaced the fuel pump.... BUT..
get a fuel pressure tester and check the fuel pressure .. low fuel pressure can cause the randomn misfire P0300, poor starting, and the poor driveability...
and .. fuel pumps can fail quickly ... some brands are just not that reliable... (ACDelco or Delphi are the most reliable... ie., less chance of having to replace the pump again soon)
if the fuel pressure is up (spec is 61 to 66 psi and the truck would not be expected to start or run properly if below 58 psi), then I would look to the ignition module .. get it tested (sometimes a bad one will still pass until it is tested 3 or 4 times ... fail as it warms up)
... and sorry, I don't know anything about MAF sensors
    • Well, I received a message from the dealer...
    • The no sound problem is the audio amplifier. The audio amp has a heatsoak issue in some circuitry which causes it to miss the wakeup handhake. If it doesn't respond within a certain time parameter, then you get no sound. I brought it in and had the software update, but after further testing the tech made the call for a new audio amplifer. The software update I belive gives more time for the amp to respond, but if the amp is defective then you can still get no audio at times. After the update it went 12 days before no sound. After doing some research, apparently the fix is a new (updated) audio amplifer, the circuitry internally has been improved to better deal with heat. I had to wait 2 1/2 weeks because at the time, it was on backorder with no eta. Well the amp came in earlier this week. I had the amp and programming work done today. After picking it up I stopped at a few places, and whenever I started my truck, the audio was on instantly, so whatever they did it appears to work because it's never had sound that quickly......Hope this helps
    • Make sure the latch mechanism is properly greased. Look at the catch for fresh marks/scratches. And see if it has moved a little, too.
    • I have the 18" black mutilspoke wheels that came with my truck. I like them as they are very subdued and look good with the 295/70's    I am sure that the next set of wheels I get will be some after market all black wheels. Or maybe some AT4X wheels.
    • Interesting question which you partly answered in the word 'potentially'. I think that is going to be a 'point of reference' inquiry. What are the touchstones?    This will sound petty but it is the main source of end fighting in threads on this topic. Define a motors "Life". Think about the various arguments that have been entertained on these pages in that very argument.    I can only speak from my viewpoint. Engine "Life" in my world is defined by power cylinder integrity. For the majority of engines it is the bore/ring interface that quits first. Loss of seal. Oil consumption and loss of power. Most Pro motor builders would agree and there is a good deal of information on using "Leak Down" as a primary indicator of bore integrity. At home a compression test is more the thing. If we can agree on that then I think CC Jensen has done its homework and I'd find it valid.    Now by my own definition, Dizzy, wife's Ecotec 2.4 I-4 has been dead since about 80K miles. And yet we have logged over 200K miles more on it. "Life" and "Usefulness" are therefore independent.      I know a mature fella right now who has just hit 300K on a Mitsubishi 3A92 NA MPFI motor and has done compression test every 100K. It was 205 psi after break in and is now about 195 and still even. He uses shelf oil but good filters and adheres to a 3K mile OCI. He even do UOA's on each of them for the first 50K.      I also know a fleet mechanic with that same motor that gets 300 to 500 K out of them but the are oil using, wristpin sloppy, skirt slapping motors. He ran one with a piston pin so loose the piston was bouncing off the cylinder head for about 20K miles before he called TOD. Both of them claim success.
