2003 Dodge Cummins Dynoed
TxDoc
The following is a compilation from several posts on the same thread.
http://www.turbodieselregister.com/forums....3e%202& threadid=55578
Thanks Vaughn MacKenzie
Last Saturday at Diesel Thunder in Spokane, Dishman Dodge brought out a '03 QC 4x4 longbed for us to check out. We passed the hat to come up with the $50 needed to put it on the rollers so we could see what it would do.
With 82 miles on the clock it put down 262hp/484tq. The dyno at Shelley's Automotive (where he had out event) is a dynojet.
While the truck is very quiet, a bit quieter than a DMax, it still sounds very good and Cummins-like (big 6) under power.
I have seen 4-5 stock DMax trucks dyno and they have been consistently in the 245-250hp range although with quite a few more miles and a little more broken in that this truck was.
Vaughn
The '03 CTD HO isn't avialable with an automatic trans yet.
At every dyno meet I've attended, the operators lockup the converters when dynoing automatic trans equiped trucks to get more accurate readings. There are very little differences in transmission hp losses between auto vs. manual tansmissions this way. This is sometimes difficult to do with a D/A, but I've seen it done many times.
it was the 6-speed truck (rated 305hp/555tq). I think the automatics are rated at 255hp. So, I would expect the DMax/Allison combo should be quicker than the new Dodge Cummins, both auto and HO versions (pretty hard to row the 6-speed fast!). . .given they are all in stock form.
It is interesting the torque number registered came in much lower than advertised torque. Another thing Dodge has been advertising is the new HO Cummins hits peak torque 400rpm lower than the DMax, supposedly the full 555ft/lbs occurs way down at 1400rpm. But a few more dyno runs will show if this is really the case or not though. Being a long-stroke I6 and given equal injection systems, I would expect torque to come in at a lower rpm. I don't know at what RPM it falls off though.
There was a '01 HD Chevy DMax that dynoed, it had a reprogrammed ECM and a box (which one I don't know) and 4" exhaust, it dynoed and sounded very good. It put down about 365hp and made very little smoke in the process.
We had an awesome time at Diesel Thunder and you guys oughta come next year if you can make it The drag racing Sat. night was awesome, one guy bolted on a set of drag slicks on his '01 Ram and nailed down an insane 11.83 @ 118mph
Here's the results of the Dyno runs at Diesel Thunder
The unlimited class (#2 + Drugs)
1st place Christian Roth BD Power 734.2 HP
Torque(dyno maxed at 1200)
2nd place Jim Fuller Diesel Dynamics 645 HP
3rd place Steve Covalt (Heberam) 625.9 HP
BOMBed class (#2 only) Over 350 Hp
1st Jason Burton (thanks PDR) 96 12v 500.2 HP 1036 tq
2nd Steve Opecensky 2001 24v 480.6 HP 960.2 tq
3rd John Triebel 1998.5 24v 448 Hp 1018 tq
4th Jon McCoy 2000 24v 436 HP
5th Jeremey Linder 2001 24v 435.5 HP 882 tq
6th Bob Novak 1999 24v 434.8 Hp 870.3 tq
7th Vince Self /Turbo Liner 2001 24v 423.9 HP
8th Josh Ulrich 2001 24v 378 HP
9th Cliff Wilson 2001 24v 370.3 HP
10th Randy Smith 2001 24v 364.9 HP
11th Dave Lockwood (02 Duramax) 362 HP
12th Kris Doran 1994 12v 353 HP 796.5 tq
Modified Class under 350 hp
1st Kjell Alsaker (99 Power Stroke) 335.6 HP 637.9 tq
2nd Erin Scott 2000 24v 333.3 HP 715 tq
3rd Mike Kerncamp 2001 24v 324.8 HP 711 tq
4th Doug Hofeldr 1998 324.3 HP
5th Jake Burkey 1998 12v 322.8 HP 708 tq
6th Ronda Kelly 1997 12v 315.2 HP
7th Bob Gates 311.5 Hp 700 tq
8th Mark Wilson (Nascar Mark) 1st gen 308 HP
9th Kent Earnest 1998.5 24v 292.5 HP 621.3 tq
10th Casey VeltKap 1996 12v 272.4 HP 607.3 tq
11th Andrew Pittman 96 Power Stroke 268.7 HP
12th Rob Alley 1997 12v 255.5 HP 565.5 tq
13th Bob Beavchaine 1993 1st Gen 247 Hp 577.5 tq
14th Andy Sims 2002 24v 237 HP 527 tq
Stock Class
1st Calvin Stack 2002 24v 237 Hp
2nd Dave Hirtle 2001 24v 229 Hp 470 tq
3rd kevin Stout 2002 24v 221.5 Hp
4th Dan Groat 2000 24v 189.3 Hp
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
    • The not as clean as one would assume theme with the new engine oil, that reminds me of comments over the years with mechanics not always being so on board with filling an oil filter, not from the center anyway due to that typically being the clean side of the filter, danger of some contaminant falling into the filter if not careful but the realization now that the oil may not be as pure as one had assumed it would surely be. Yes it would be possible to fill from the small holes but that means messing with something to prop open the anti drain back valve if the filter is so equipped and not damage that valve in the process. Me, I have hardly ever prefilled an engine oil filter however I have prefilled diesel fuel filters with a filter on a fuel bulk tank and for anyone that has messed with diesel engines with filters and units that have a limited or no way of priming them, putting on a dry filter is a bad day to say the least with those crappy systems. But anyway back to not so clean engine oil, indeed perhaps its not so bad after all that I have not made a practice of prefilling oil filters.    As Grumpy Bear commented on keeping things clean, that I really have to wonder what the typical practice is at a dealer or any other shop that changes engine oil, do they make sure to wipe or wash off the oil plug and certainly if it fell into some gunk or onto a dirty floor, or that they wiped the filter mounting flange and didn't go and use some dirty rag and end up adding dirt to the inside of the head of the filter mount. Or be careless in how they stored or handled the new filter and if they were bumping into items under the vehicle with the filter opening facing up and having dirt drop right into the filter and if so right into the threaded center that is on the clean side. The top side, did they clean away the built up gunk that may be around the filler before removing the cap or to be really careful at that point that something right close to the filler hole that was hidden under the caps flange won't fall into the engine. Or did they clean the funnel or was that just laying there covered in oil from the oil change before and dust kicked up from sweeping the floor stuck to the oil and now that will go running into the next persons engine due to just not cleaning the funnel as "they won't know anyway" attitude as that young guy is more worried about taking a break so he can go outside and smoke a joint. Just random points that came to mind when I think about what some hired personnel may do that the shop foreman has no idea of or perhaps the whole attitude of some shops may be "eh ... who cares, they will never know the difference anyway".
    • $3.69 for 87 octane.   $4.24 for Diesel in town.
