Duramax Dual Exhaust
I've looked at some of the replacement HP exhaust systems for the duramax and they all seem to be single exhaust. Why is that? Why don't they run true dual pipes (assuming there is no cats like on mine)? This is my first diesel so maybe it is a no no on them??
Thanks
It's fine to run duals, but most don't. A single outlet system is expensive enough with the big pipes(4"). If you want duals, I would get dual 4" pipe ran the whole way from where it starts at 5". I have a chrome 5" tip on mine, but it is hard to keep clean with the diesel smut coming out of it. Also, stainless is spendy but worth it. On mine, I just had the muffler removed and a straight pipe installed along with the 5" tip. It is a bit loud, but not bad in the cab.
4" duals do look great, but it costs more money. The folks at Diesel Performance Parts.COM are introducing a 4" dual system with 5" tips for about $799. Their single 4" exhaust with a 5" tip goes for about $490. An extra $300 for looks rather than performance - no thanks, the single system looks tough enough. Besides, dual exhaust running out the arse of the truck makes it look like a GASSER :devil: LOL
I always ask myself self- "Why??" when this question comes up.
To each their own I guess. From an efficiency stand point you'd be hard pressed to convince me the duals out perform the single. In all actuality, the duals will under perform in most cases, and actually "plug up" the engine so to speak. JMHO.
I'm not sure what you mean by "plugging it up"? I would think it would breathe better, but I'm no diesel mechanic.
I can see though, that maybe a single 4" would be plenty.
Forum member "Broker" runs duals on his Duramaxes. This is what I read anyways.
I had straight pipe duals on my 5.3 gasser and did run into trouble with not enough back pressure. I would think this wouldn't happen with a diesel.
Seeing that the Duramax aftermarket exhaust starts at the downpipe - A single 4" system would be the easiest way to get from A to B... I assume. In addition, the fewer bends in the pipe offer the less restriction for a turbo diesel.
Where is the turbo mounted in the exhaust stream? Is putting a dual pipe setup on a Duramax diesel next to impossible?
Also what size is the OEM pipes on it? It looked pretty large to me
I don't know if it's impossible, but I don't know how a true dual exhaust would be fabricated. The downpipe is a single pipe that runs from the turbo into the exhaust system... The dual exhaust that most of the diesel guys offer are usually single in / dual out at or after the muffler.
The stock exhaust is 3.5" with a pretty restrictive muffler. A less restrictive, 4" single exhaust with a straight through muffler can lowers egt's by 150-200 degrees.
I guess you could put a 2nd turbo on and run "true" duals all the way. :thumbs: Now THAT could give you some SERIOUS boost. My brother-in-law did that with a pre-turbo Ford diesel. Man, did that change things. Made it almost as good as a Chevy' :devil:
    • I had skimmed through that article when you posted the link and honestly I felt rather defeated in a sense and realized that all these years in changing oil that in fact putting in what I was told was a good quality oil was probably not filtered as well as it should be although the filter put on the engine would be what ( as long as it never went into bypass mode ) would be the final filtering of the new oil that the engine components would first see, but then the filtering media itself is not up to par to what is ideal because a full flow filter would be too restrictive to filter fine enough for the engines best outcome in the long run. Only one of our tractors over the years which was a Versatile with a 855 Cummins had a separate bypass filter, some engine manufacturers did spec a partial bypass system within the main oil filter but I don't believe any other trucks or equipment I was servicing used such a filter. No doubt a product like the Amsoil bypass system is of benefit as long as nothing goes sideways with the extra plumbing and filter such as a rupture/leak that could cause the oil to pump out of the engine ( yes that Versatile had a remote canister with hoses routed to it as well ). With the idiot egr system on a diesel and as a result forcing a lot more soot into the oil, that certainly isn't helping the diesel engines cause or as you pointed out the GDI engine issue with creating more soot and aside from having a fancy secondary filtering system, changing the oil more often helping lower the total soot load.     So oil manufacturing and the end product is not something one can control and I wonder if there are specs on what various oil packaging companies produce in particle count or size. As to the filtering, if the OEM is not designing a filter size and spec that is really what it could be, they too are short changing the end user and so what is the answer. Of course as you say the oil side can only do so much if the air side isn't keeping up its end of the picture and air filters are only so efficient and if in a dusty environment such as farm or construction or driving gravel roads there is a lot of dirt to filter out and some of that ends up into the air stream.    Of course the irony in places like where I am where they dump the salt on the highways but also will mix in some calcium or outright pure calcium for problem road area's, or using calcium as dust control on gravel roads, the vehicle that gets used in that environment may rust out before a properly engineered engine and maintenance finally wears out so one has to face that reality in the rust belt.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
