NAV and 6 disk changer in a Silverado
Just wanted to post a pic of my finished install. Everything works good, just need to get to the dealer next week to program my AMP for my surroundings. The AMP came out of a Hummer, so i need them to program it like a sierra denali to make it sound better. Right off the bat this AMP sounds TONS better than the stock silverado AMPs, much more adjustments and sound clearity. Cant wait till its tweeked. There were some small wiring MODs that were needed at the AMP and a little trimming to do to get the 6 disk changer in the console, but it looks sharp, and best of all...it looks like it came from the factory like this. I have to thank SPERRY and Pbuilder for helping me out with the DOCs i needed to make the wiring changes!
  • Replies 923
Thanks Linda,
It looks really nice. I'd definitely like to do something like that in my Sierra sometime. I'd like to add XM too if possible tho too. I'll have to go back and look throught the previous posts to see what all you needed to put this together.
well, with help from numorous people ive acquirred the needed documents and wiring schematics to do it with ease now. So let me know if your gonna give it a shot and i can make it pretty easy to do for you. The hard part is finding the pieces. The NAV head unit, the AMP, and the 6 disk changer will set you back a few pennies, but in my opinion its a really nice setup. Best of all you retain a nice factory look.
I didn't see any close ups showing the bezel around the changer. I'm guessing that was a custom fabrication or do they put the seperate 6 in dash cd into Tahoes so you could borrow parts. Did the amp need to have the VIN reprogrammed by the dealer like the Nav Headunit? Your install looks great! Great job!
actually it was a custom cut. A steady hand a straight edge and a razor knife was what i used. there is a pocket there on the bezel normaly and what i did was take some measurements on how deep into the pocket i need to go to get a nice tight fit. 3/16" from the face i traced a straight line around the outside of the bezel, except the top of the bezel which needs to be traced on the inside because of the molded plastic reinforcements. The plastic is soft enough that after scoring it a few times it cuts right through. Suprisingly enough to me...NOTHING needed to be programmed to work other than you will need to have the theftlock removed at the dealer. There is a way to get around the theftlock, but its only temporary. Even the 6 disk changer worked perfectly without needing to be programmed. I will however be taking it in to be tweeked to my enviornment.....the AMP needs to be setup as if it were in a Sierra Denali as i have a silverado ext. cab. Also no, there is not an option for the in dash 6 cd changer in the Tahoe...only the Yukon denali and escalades. As of now the AMP and system sounds way better than the other AMP did, i cant wait to hear it tweeked out for my truck. Oh, and here is a close up shot that you wanted......
http://files.automotiveforums.com/gallery/...&cat=500&page=1
linda,
everything looks nice. :loser: i'm trying to install the 6 disc changer in my yukon and i can't find the cable to connect the cd changer to the radio. if you don't mind, please tell me where you got the cable (or harness) to connect the 6 disc changer. thanks.
Linda,
It is something I would like to do in the future, definitely. I've seen the other aftermarket nav systems and like how the factory one looks. How are you getting the theftlock problem fixed? I'm also a little confused about you saying the amp still needs tweaking. Right now I have the Bose system with the integrated 6CD unit.
Poonis: In order to make the changer work you need a head unit with changer abilities....i dont think the 6 disk head unit will controll a changer (cause its already a changer). If you have a head unit like the single disk or single disk + cassette, you can probably add the changer to those. What you need to do is get yourself a 9 pin patch cable from GM, part #15312903. Then you remove the pins from the connector on one end (the other end will plug into the changer). Then follow the correct schematic on pluging the pins into the 12 way connector on the back of the head unit. When you get to that point, i can show you where they hook up. Remember, any GM vehicle 2003 and up is using a common classII data wire for communication. If your vehicle is 2003 or newer, you will need a changer that has classII capabilities.
Bigdogs: You can TEMPORARILY bypass theftlock by doing the following:
1. turn the key to ACC
2. wait for the "theftlock" screen to apear
3. unplug the main harness from the back of the radio for 3-5 seconds
4. plug it back in with the key still in the ACC position (ACC...not RUN)
5. radio will work as normal until the key is turned off
when i say the AMP needs tweeking, what i mean is that these high end AMPs are programmed depending on what type of truck cabin they are in. The escalade exts have 6 speakers i think, and the Denalis have 8. I think the Hummers have 8 also, while the sierra denalis have 6. So you program your AMP for the type of cabin you have, so it sounds full and rich.
ahhh ok gotcha... now I understand what you mean. I heard (not sure how true it is tho) that the Bose systems have an amp basically wired onto each speaker. That is why swapping to a different speaker is more difficult with them.
Linda, I drive a 03 Yukon and have the single disc head unit with cassette (just like the one's that came with 03 Denali). I just ordered the patch cable from GMPartsDirect just now and hopefully it will come soon. Now I can get the dust off the 6-cd changer. I hope to talk to you when I get my patch cable so you can show me how to complete the cable connection. Thanks again. :loser:
sure....just let me know. Are you sure the changer you have is an 03' or newer? Also, maybe i should have mentioned.....you will need to know how to solder a little as well. You can alsways use crimps i guess, but im a big solder fan.
How can one tell if the changer is 03 or not? :cool:
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
