Intake Shoot-out w/Dyno sheets
So here it is, long overdue. I know a few of you were waiting for results... I hope you waited !!! It'll be worth it :cheers:
This chart was when the truck was new, at about 6k miles. All stock except the Volant. 47* degrees, low humidity, DynoJet dyno. I remember the day- it was running great. Sweet air that day. And the truck got to cool almost to the point it was too cool right before pulling.
(I posted both of these cuz one got jammed or something in the printer and got extra numbers printed on it)
Here are three consecutive pulls from Wednesday. Terrible day for dyno'ing- 95+ degrees, high humidity. Truck was running okay, about as good as can be expected in Texas heat.
Pull #1 is Wester's tune and Volant
Pull #2 is Wester's and stock airbox
Pull #3 is Wester's and aFe intake
I went from 235hp and ~280tq stock to 302.8hp and 328.6tq, gains of about 68hp and 50lbs of torque, with an intake and tune... for less than $1000 :D !!!!! Wanna talk bang-for-the-buck ?!!!!!?
The Wester's tune alone was worth 53.2hp and 45.7lbs over stock (and with a slightly better than stock intake :P:D )
The aFe was worth 14.6hp more than the Volant, 20+hp over the stockbox !!!
And, even better, the aFe moved my torque peak down by 400rpm, from 4100 to 3700 rpm- way cool :D It jumps out of the hole so much harder now !!!
And- the thing screams on top !!!! There's noticeably more response and power everywhere with the aFe over the Volant. The thing sounds awesome, combining with the tune and stock exhaust for exactly the kind of sound I like- quiet most of the time, very noticeable growl at heavy throttle, and a sweet wail at full throttle and 5000+rpm :D:D:D
It is a WAY-sweet system, the way all the pieces fit together make for as seamless a transition as possible from part to part, whereas if you look at the stock intake- and the Volant, since it reuses some of the stock couplers- there will be about a 1/4" ridge the entire diameter of the tube, in two places, totally disrupting and obstructing air flow. The aFe is super-smooth, all the way thru, with no obstructions at all. A very well designed and thought-out system, and a very high build quality- it has a wicked aluminum venturi piece that throats down the filters HUGE opening. The filter also pulls from the top as well as the sides. And the main tube has a small indention molded into it to clear the fan shroud. The Volant did not and was so tight, I had to take an Exacto knife to my shroud and trim it back. Again, very well thought out. I give it :cheers::flag:
And, uh....
Anyone still doubting Wester's abilities ?!!?
While I agree the intakes probably did a little better because of the tune, and the tune did a little better because of the intakes, there is still just no denying the results. Like someone once said, there are crappy turbos and blowers that barely beat these results :P !!!!!! Nothing comes close, value-wise. Nitrous may be cheap horsepower, but it's not even a consideration for most, and to do nitrous correctly... ain't cheap.
Now, I know comparing one dyno to another isn't always a fair comparison, but let's consider- it was COLD during the first dyno- great air, and was over 95* and high humidity during this last round (and forgot to add, truck didn't get to cool too much between rounds, considering the ambient temp). Both are DynoJet dynos, and my G-Tech has always confirmed whatever numbers I had at the time. You can see (till I change it :P ) in my sig that the G-Tech claimed 282hp, and it was actually 288. G-Tech manual states it will always be lower than a true dyno, since the G-Tech has to overcome wind resistance where a chassis dyno is stationary, sooo...... I'm quite comfortable with these numbers :D
Hey, Chad, where ya at ?!!? Satisfied :P
Oh... and everyone's results may vary... but these are mine !!!!!!
302+ at the wheels :D:D Wait till I get serious :D !!!!!
Hmm... I see them, but I loaded them.... copy and paste the properties in the address bar.
At least I would have known to do that :cheers: !!! YOU SUCK WORSE !!!!!
Thanks, I'll fix it ;)
I get a security error when I try to paste the url...
Alright, fine :cheers:
I tried to cheat and just link them. I'll load them on to my own space later and redo it....
Hey- going to HRP. Anyone down ?? I'm leaving here in a few minutes...
Did you get to run any times @ HRP ?
I saw the members over at LS1Tech giving you a hard time on your Dyno numbers. I hope you got some good times to shut them up.
Dyno #'s are hard to compare when two different people are dynoing. Some can Lock the Torque Converter for about a 15-20 HP gain while others leave it alone. Thunder Racing here in Baton Rouge will do it when asked OR when you are comparing your stuff to theirs. You gotta watch them.
However, I can't see your dyno tags, but you did write your gains. I have a stock intake on my truck right now and your gains from the Volant to the aFe are impressive. Do you have a pic of the aFe system or maybe a link to them?? You gains are undeniable if the same guy tested them.
Alright, can y'all see 'em now ??
100R1, nah, didn't make it to HRP, got too late. Went to HMP instead, but got really lame numbers- 10.3's. I've gone 10.02 there before, with 2.2 60' ON WHEELSPIN. Last night, best 60' was 2.35 with no wheelspin...
It was hot and VERY humid and sh!t just wasn't running as well as I'd hoped. Pretty disappointed with the results :cheers:
Next time !!!!!
vhato, I know what you're saying. And how much you wanna bet that even if they were on the same dyno, but 1.5yrs apart, it'd still be questioned, and somewhat justifiably. But by the same token, with all the other support I have for the numbers, in the way of G-Tech and timeslips and just how the danm things runs, I'm still comfortable with the numbers fairly accurate.
The intake shoot-out numbers, I can't see how anybody could question those at all- same day, dyno, operator... truck !! Hey- heat-soak, included ;) !!!!
The aFe intake just flat kicks-ass !!!!!!!!
The intake system looks like this:
but I have this kind of filter:
I'll get a few pics together on this, on the MASSIVE obstructions created w/in the stock and Volant intakes here in a bit and post them for y'all ;)
Bottom line, WITH GOOD DOCUMENTATION, the aFe laid waste to the competition !!!!!!!
And, overall, Wester's makes ALL the difference :cheers:
does that filter ever get dirty/wet when you're driving in the rain?
I have thought about putting an intake on with the Nelson tune over the stock airbox....
HD, getchya a better breathing intake- it'll make a huge difference. Like the tune will compliment the intake, and the intake compliments the tune :fume:
I can't say with 100% certainty that it won't ever get wet, but I think it's pretty unlikely except in the worst conditions, like maybe splashing huge puddles at high speeds type stuff. It's in the stock location, the 1/2 box it mounts with covers a lot of gap... and there's just a bunch of junk in that area to block it. I'm not really overly concerned with that.
When I get ram-air, then I wonder what you do in heavy rains ??
try this.
LS1Tech just changed the truck boards to a stand-alone sight. Mighta screwed that first link. If this link doesn't do it, it's got basically the same title as this one.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
    • The not as clean as one would assume theme with the new engine oil, that reminds me of comments over the years with mechanics not always being so on board with filling an oil filter, not from the center anyway due to that typically being the clean side of the filter, danger of some contaminant falling into the filter if not careful but the realization now that the oil may not be as pure as one had assumed it would surely be. Yes it would be possible to fill from the small holes but that means messing with something to prop open the anti drain back valve if the filter is so equipped and not damage that valve in the process. Me, I have hardly ever prefilled an engine oil filter however I have prefilled diesel fuel filters with a filter on a fuel bulk tank and for anyone that has messed with diesel engines with filters and units that have a limited or no way of priming them, putting on a dry filter is a bad day to say the least with those crappy systems. But anyway back to not so clean engine oil, indeed perhaps its not so bad after all that I have not made a practice of prefilling oil filters.    As Grumpy Bear commented on keeping things clean, that I really have to wonder what the typical practice is at a dealer or any other shop that changes engine oil, do they make sure to wipe or wash off the oil plug and certainly if it fell into some gunk or onto a dirty floor, or that they wiped the filter mounting flange and didn't go and use some dirty rag and end up adding dirt to the inside of the head of the filter mount. Or be careless in how they stored or handled the new filter and if they were bumping into items under the vehicle with the filter opening facing up and having dirt drop right into the filter and if so right into the threaded center that is on the clean side. The top side, did they clean away the built up gunk that may be around the filler before removing the cap or to be really careful at that point that something right close to the filler hole that was hidden under the caps flange won't fall into the engine. Or did they clean the funnel or was that just laying there covered in oil from the oil change before and dust kicked up from sweeping the floor stuck to the oil and now that will go running into the next persons engine due to just not cleaning the funnel as "they won't know anyway" attitude as that young guy is more worried about taking a break so he can go outside and smoke a joint. Just random points that came to mind when I think about what some hired personnel may do that the shop foreman has no idea of or perhaps the whole attitude of some shops may be "eh ... who cares, they will never know the difference anyway".
    • $3.69 for 87 octane.   $4.24 for Diesel in town.
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
