Chrome Tow Hooks On Nbs
Just got my chrome tow hooks installed and thought I'd share some pics. 4 bolts, 2 nuts, 2 hooks.
THE GOODS:
BEFORE
AFTER
Daddy
Looking rich...how much were those again?
Thanks!
$100, GMPartsDirect.com
Daddy
Hmmm, just may have to add those to my list of goodies...
Thanks for the pics (even though they may have just cost me $100)
Thanks!
Daddy
Supposedly, they increase HP and MPG so it's well worth it! :troll:
Daddy
Now that's funny !!! Tell that to your wife when you dump a $100 bucks for chrome tow hooks..."But honey it increase's HP and MPG !" haha
:troll:
Well, technically, the chrome finish probably does have a lower coefficient of friction with air than black paint/powdercoat does, so over a ten year period, you may save 1 or 2 drops of gasoline. :lol:
:troll:
Do you have part #'s for the chrome (and black?) tow hooks from gmpartsdirect.com? I emailed them but no response.
:troll:
Actually just checked my e-mail again and they responded.
Chrome hooks: # 19156956
Black hooks: (Single, seems to be single, not set of two): # 1522657
Looks good.
I don't know very much about this place, but you can save a few bucks by ordering them from chevy.carcareoutlet.com ($88).
Looks good.
How much is the shipping? Mine were $104.94 to my door. GMPartsDirect.com is also a site sponsor so I think it's only right to let them make some cash, as long as their price is reasonable, as they help keep this great site up and running for all of us.
Daddy
Looks good.
Daddy
I'll normally buy from the site sponsors as well, all other things being equal. However, when you get to talking about a discount in excess of 10% then I'll look elsewhere, as will a lot of other people. It all adds up.
Besides, whose to say that at some point in the future, the company I referenced doesn't become a site sponsor as well??????
Looks good.
Daddy
Shop where you'd like, I was just explaining my stand on the matter. I'm still curious the cost with shipping though. The set on GMPD is only $94.99. We're talking about 7 bucks and that could very easily show back up in the shipping.
Daddy
  • 1 year later...
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
