Front Wheel Beaings Worn Out
KKtrucking
Hey Gentlemens and Gentleladies?;
Have any of you folks ran accross the front bearing/hub assemblys being worn out with 50,000 miles on the truck?
2005 3500HD 4X4 ext. cab Duramax?
I had new tires put on today and while it was jacked up the mechanic called me over and said "lookit this" Grab the tires at 12 and 6 o'clock and they moves in and out 1/4-3/8". The scary thing is I never felt it in the wheel and the tires aren't worn funky. What's even worse is I've turned wrenches for 25+ years and service the truck on a 4-5000 mile schedule, jacking up the front end and all, no play in any tie rod or associated part , so I'm kind of shocked. Its far too early to be checking bearing play, GM claims this is a first (yea right). I have to bring it to the dealer for "consideration" L&R bearing assemblys are over $200 so I'll be driving an 08 F350 before I spend that kind of cake.
Any one ever seen this?
Thanks all
Yes have replaced many hub bearings before from 1500's to 3500's. Do you have oversized rims and tires because thats the leading cause? Being your a wrench turner and probaly pretty good with math buying a new new ford and replacing both front hubs just don't add up. Do yourself a favor keep the chevy. :D
I replaced the left side last summer at 100,000 miles. The right side is fine.
+1 on keep the Chevy.
Factory wheels and tires
I just think its coming up short in the normal wear and tear department with 50000 miles. I could have said Dod...no I couldn't!!!
Are you a good customer at your local dealer because the service manage has the ability to goodwill your repair. Depending on your service history he can ask for a hundred dollar deposit or nothing if your a real good service customer and warranty your repair. Can't hurt to try.
  • 1 year later...
Driver side went at 26,000 left side just went at 26630. 06 gmc crew cab. Bought it new an it is now out of warrenty because of 3 years. Also both front tires worn down to the wear bars just on the inside band of the tire.
I've seen it happen.
And 200 bucks is pretty cheap for a dealer installed wheel bearing.
They're 30 bucks each if you want to replace them your self.
Thats just the bearings them selves...the whole assembly ranges from 150-278
Edit:
Sorry...I screwed up.... the 1st set I looked at was for a 2WD.
Either way...I'd rather spend 400 bucks on fixing than 40G to buy a new truck.
Hey guys. All good information here! Now that I've read this post, I think I may possibly have a wheel bearing going bad on my 2006 Silverado 4x4. Having just rolled over 100K I noticed just a couple days ago my tire on the driver side is wearing real bad just on the inside edge and there seems to have been a little more road noise than usual lately. I've been running Firestone Destination A/Ts the past 30K miles and the passenger side still looks darn near new evenly across the tread whereas the driver side looks the same except for the very inside edge showing unusual wear. I've been busy with work and haven't had a chance to check it out as of yet but after reading this post, this seems to be a common problem with many of our GM trucks so I'm going to check it out in the next day or two. If it turns out to be the bearing, would you guys recommend replacing the bearing only or should I go for the entire hub w/bearing assembly replacement. I've seen these advertised on eBay with or without the wheel sensor for under a hundred bucks. Then again, if this turns out to be the problem, I'm wondering if I should just go ahead and replace both sides, since it's likely the passenger side may soon follow down the road a ways. I used to always say, 'if it ain't broke, don't fix it' but then again, I believe in preventive maintenance. Uncle Sam taught me that!
If the tire moved in and out by grabbing it at 12 and 6 wouldnt that be upper and lower ball joints?
Moving in and out is bearing...rocking up and down is ball joints.
you can't get just the bearing ,there is a wheel speed sensor in there,just bite it and get er done,
its easy to feel a wheel brg at 12 & 6 ,
with suspension and truck lifted off the grd ,upper BJ is able to push in at the top and if theres movment or a torn boot ,its done
lowers are chk'd with a pry bar under wheel and visual and feel for movement,spec is quiet abit for GM warranty ,78 thou .but after warranty thats no good ,lol
Just did the drivers side for the first time on my 01 at 173,000 miles. About $180 including tax for the entire assembly with a 1 year warranty from Kragen. Very easy to change. Should only take you about 30 minutes and 3 beers per side.I will suggest you hose down the bolts holding the bearing on and the brake pad cage with penetrating oil the night before you do the change.
I had one go on my '94 K1500 at 230,000 miles. My father replaced his on an '02 HD2500 at 80K or so & I have a friend that used to own an '04 K1500 crew -- he had both go at under 30K! Seems like GM had some cheap vendors in the bearing department from '02-'06.
So far my NBS '07 is doing fine -- even cornering like an idiot with 22" rims that weigh 92lbs. each .... we'll see how long they last.... :lol:
I have an 01 and had to have the left front wheel bearing replaced around 30k miles. Thanks to the web I can see just how much quality is built into my truck. This is 1 of the many many many many things I have had to replace.
Hey guys. Hers an update on what I thought was a wheel bearing problem on my 06 Silverado. Turns out both side wheel bearing/hubs are snug as new. I jacked up the truck, removed the wheel and let the suspension hang. Then I removed the caliper, suspending it with a wire hanger out of the way. Then I spun the rotor to check for bearing noise or roughness ... there was none. I could get the rotor to spin freely for about 1/4 turn or so. It wasn't tight and certainly not free-wheelin' loose either so I'm assuming it was acting normal. Then I grab the disk at 12 & 6 in an attempt to rock it back and forth. Nothing. I repeated the process at the 9 & 3 positions. Nothing. I checked both sides. Everything seems tight. I tried getting the ball joints to move but there is no play there either. Tie rod ends, pitman/idle arms and steering linkage seems all tight. All I can think of now is front end alignment is off. The only other thing I noticed after putting everything back together and lowering the truck with the front end resting on it's suspension (with no load inside the rear bed and 1/2 tank of fuel on board) is the rubber suspension jounce bumper on the driver side is touching the lower control arm stop whereas the passenger side has about 1/4" of clearance between the bumper and stop. Both rubber bumpers appear to be normal and in great shape, not deformed or anything. This would seemingly relate to a possible height adjustment problem so now I'm wondering if this may have something to do with the inside wear on the driver tire. Anyone know of a topic on this?
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
    • The not as clean as one would assume theme with the new engine oil, that reminds me of comments over the years with mechanics not always being so on board with filling an oil filter, not from the center anyway due to that typically being the clean side of the filter, danger of some contaminant falling into the filter if not careful but the realization now that the oil may not be as pure as one had assumed it would surely be. Yes it would be possible to fill from the small holes but that means messing with something to prop open the anti drain back valve if the filter is so equipped and not damage that valve in the process. Me, I have hardly ever prefilled an engine oil filter however I have prefilled diesel fuel filters with a filter on a fuel bulk tank and for anyone that has messed with diesel engines with filters and units that have a limited or no way of priming them, putting on a dry filter is a bad day to say the least with those crappy systems. But anyway back to not so clean engine oil, indeed perhaps its not so bad after all that I have not made a practice of prefilling oil filters.    As Grumpy Bear commented on keeping things clean, that I really have to wonder what the typical practice is at a dealer or any other shop that changes engine oil, do they make sure to wipe or wash off the oil plug and certainly if it fell into some gunk or onto a dirty floor, or that they wiped the filter mounting flange and didn't go and use some dirty rag and end up adding dirt to the inside of the head of the filter mount. Or be careless in how they stored or handled the new filter and if they were bumping into items under the vehicle with the filter opening facing up and having dirt drop right into the filter and if so right into the threaded center that is on the clean side. The top side, did they clean away the built up gunk that may be around the filler before removing the cap or to be really careful at that point that something right close to the filler hole that was hidden under the caps flange won't fall into the engine. Or did they clean the funnel or was that just laying there covered in oil from the oil change before and dust kicked up from sweeping the floor stuck to the oil and now that will go running into the next persons engine due to just not cleaning the funnel as "they won't know anyway" attitude as that young guy is more worried about taking a break so he can go outside and smoke a joint. Just random points that came to mind when I think about what some hired personnel may do that the shop foreman has no idea of or perhaps the whole attitude of some shops may be "eh ... who cares, they will never know the difference anyway".
    • $3.69 for 87 octane.   $4.24 for Diesel in town.
