Major Wheel 'wobble'!
sgchap3
Hey guys. I just had my inter. med. steering shaft replaced about 2 months at the dealer and they said my tires were looking pretty bad so I dropped a good amount on some Goodyear silent armor 20/275/55's and they are awesome! HOWEVER, I now have a major problem in the form of a horrible and annoying wobble at 65 - 75 mph! I've been back to the Goodyear dealer 3 times for new balancing and stuff and they said they are as prefect as they can get them.
I difinitely think there is now something else going on! I'm taking it to the dealer this Wed. to have them look it over. I know my shocks are starting to really feel 'soft' (feeling ever little bump or crack) and I'm about to replace them. I did also 'upgrade' my tie rod ends, idler arm and ball joints about a year ago with MOOG replacements. I also have upgraded sway bars front and rear...
The truck has just now got 40k miles
So I'm VERY much wanting to get rid of this 'WOBBLE' too and the Goodyear guys feel horrible too since they put these new badass tires on and now I'm having problems...
Also there is a clicking, tapping 'electiric' snapping noise coming out from under the truck somewhere. Hard to pin point. Just started noticing it too and was going to point it out to the dealer too...
I'm going to ask the dealer to check the following:
1. Tie rods
2. Hub assy.
3. Steering arm(s)
4. Bearings
5. Bad tire(s) Goodyear says no
6. Bad rim(s) Goodyear says no
7. U-joints
Anything else anyone can think of???
65-75 mph doesn't sound like bend or balance. Sounds more like lateral runout harmonic (wobble.) I recommend further investigation by spinning the wheels on the truck under power while on a lift and observe.
Ok hubby is that something the dealer can do and what can/would be causing that?
Any shop with a lift could do it. You may want to get a second opinion this way you may discover an unmentioned tire defect by your tire dealer. The fact that you have no vibration at higher speeds means that the tires are balanced, so what's left is possibly a wobbling wheel (bent out of 90 degree plane with the spindle,) or a defective tire that has lateral (side to side) movement. Both of these conditions could balance, but exhibit vibration harmonics at various speed ranges.
On a lift the rotation speed could be reached and you would see the effect and location of the vibration, as the wheel should bounce. If you have 4WD you could spin all wheels at high speed without dismounting any from the vehicle.
Typically, if you can feel it you can see it in the movement of the wheel. A lateral runout of .010" - .020" should be fairly easy to see. If your technician is game, a dial indicator as is used to check rotor runout on the vehicle could give you a good idea of where the culprit is.
BTW, do you feel the problem in the steering wheel?
Minor thread jack. Hubbycap, you're the one that does wheel repair, correct?
He is, he's helped me out before. Great guy to deal with. :D
Yes Hubby I do feel it in the steering wheel and it very annoying and almost scary to drive cause it shakes so bad it feels unsafe... I'm going to ask the Chevy dealship to do what you said here first then the tire or garage I get my work done at too...
Check the idler arm my blazer did the same and that was the problem, I'm not sure what yours is but I would check that or the pitman arm/
Just something else to add:
So something else I have noticed the last weeks or so watching this 'problem'. In the morning it's much worst when I first drive, it's about 3 miles from my house til I jump on the highway and go 65+ and sometime in the afternoon or early evening when it's warmer out or the truck has been driven it's almost not there...
So I went to Goodyear today and they pulled off my 2 front tires. They said the one was 'hopping' around on the machine and they replaced it with a new. An hour later I jumped on the highway, hit 65 and still 'wobbling'...
The truck is going to the dealership tomorrow all day and I told them to look over EVERYTHING! Let's hope they fine somthing or I all already told the Goodyear guys I'm not liking this whole thing...
Thanks I'll see whats up with the dealer tomorrow and go from there. I was also thinking these tires might be alittle to 'tready' for my truck and looking at something else they have (Goodyear) Fortera Triple Tred ove the more aggressive Wrangler Silent Armors I got...
Is there any change in the wobble if the wheels are swapped between the front/rear?
bbwb
Dealership confirms it's the tires... Said they aren't balancing right and they tried and still got the 'wobble' plus the one is hopping. They said get different tires or road force balance these and I'm thinking new Fortera Triple Tred's cause the Goodyear guys already offered...
    JimmyB4
    JimmyB4
  • Who's Online   5 Members, 0 Anonymous, 774 Guests (See full list)
    • I’ve own several successful businesses. I’ve bought homes and lived in different states. I’d witness several generations buy homes and survive in different economic circumstances. You get awful sippy when people have different experiences than you do. You live a life. I’ve lived a life. It seems our experience has been different. You can point out generalized statistics. Some people learn how to thrive when the odds are against them. Living in different states does make a difference in a persons quality of life and economic outcomes and opportunities. That’s a fact Jack. It’s my truth, my life. Hard work and long hours the right environment made my families life easier. And yes moving to a different state increased the odds of that happening. Stats are generalized. People who thrive don’t make excuses. They beat the odds. Others get mad and point to those statistics. I guess that’s you. My post pointed out how you helped people beat the odds. Somehow your panties got in a wad. Go figure.
    • Good question, I don't remember for sure but I believe it was the HD. I will check and get back to you.
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
    • Probably a one and done post, but do you have a CEL on the dash? Was having issues with my transmission, fortunately only a week, and it turned out to be the transmission harness. Valve body was in good shape, so new harness with all the sensors attached, new fluid, and filter. Seems to have worked so far?
    • Two interesting tidbits of information which are NOT related were just released.   One, regarding the possible thrust bearing issues / engine failures with the 3.0. Demonworks just did a segment in which they believe they may have found "a" or "the" cause of thrust bearing failures: A missing thrust bearing. If the engine doesn't have all its thrust bearings from the factory, the missing bearing can cause extra play which ends up destroying a nearby thrust bearing which then sends metal through the engine.       Of other importance, Lake Speed Jr released some interest information regarding oil weight selection for the 3.0. Comparisons of:   AcDelco 0w20 Dexos D Mobil 1 ESP x2 0w20 Dexos D Mobil 1 ESP x2 0w30 Mobil 1 ESP x4 0w40. Mobil Delvac 5w40   Spoiler alert: The Mobils are PAO Ester -base and the ACDelco is a Group III base. Mobil shows lower wear in their tests for similar weights. Additive packages between 20-30-40 weight ESP's appear to be the same, but only 0w20 is Dexos D licensed. Wear is even more reduced with 30 and 40 weight ESP although all perform very well and resist shear and provide very similar viscosities within temperature operating ranges in the 3.0.   There are even more surprises, so just go watch it.
