Without being tacky... not much will help. Proper inflation of the tires and driving easy and maybe a little slower are the biggest gainers in MPG. Most so-called MPG accessories are just designed to make the seller rich. Intakes and exhausts are really minimal performance gainers and do nothing for fuel economy. They sound better though.... and that probably results in less MPG because you drive it to hear it!
SSSSSSSSSSSSSSSSEEEEEEEEEEEEEAAAAAAAAAAARRRRRRRRRRRRRRRCCCCCCCCCCCCCCCCHHHHHHHHH
HHHHHHHHHHHH
I think what Dan is trying to get out here is that there is a lot of discussion on this subject if you go do a search on it. :uhoh:
HHHHHHHHHHHH
Yeah Jim said it better. :D
It's been covered ENDLESS times. The search button has lots of answers. It's really neat, actually.
thanks zembonez for helping im glad someone can help instead of saying search because i didnt find anything so...
but has anyone put anything on there truck that helped a little
Drafting, an anti-gravity device, and a sail. :uhoh:
To answer your question though, there's not much you can really do besides keeping the tires a reasonable size, at the proper PSI, and keeping your truck well maintained.
I'm thinking of inventing an HHO sail. the HHO would be blown in the direction of the sail and since it is lighter than air, I would get lift... making my truck lighter and therefore more fuel efficient.
RIGGS?
RIGGS?
RIGGGGGGS?
Brett... In here we will pick on you but it's just for a little clean fun. I've seen you in here long enough that I bet you have that figured out.
    • I'd change the fluid and start there.   198F is nothing for the 8L90.  They typically operate 180-200F stock.
    • Looking for help!   2019 GMC Sierra 1500 - 5.3l 4x4 8l90 61k miles - truck is in Arizona, was over 110 outside on Monday when this whole situation transpired. Never had any major issues with transmission until this point:   Truck sat outside my construction office for approx 1 hour idling before I realized, ran around the job site wrapping some things up for the day and then left. Went to get food and sat in the drive through for approx 30 minutes idling. As soon as I pull out of the drive through and onto the main road, rear tires lock up and feels like transmission fell out of the truck. Shifted to park, shut the truck off and tried again, same thing happened. Was able to reverse into parking lot (truck slammed into reverse). Let the truck sit turned off for 10 minutes before trying again, but it continued to happen. Towed truck back to my house. Highest the trans temps reached was 198.   Friday, after work I start looking into the situation. Truck sat in my driveway untouched all week. Truck is now driving like normal, transmission doesn’t get over 185 degrees when trying to heat it up. Got up to 60 multiples times with no issues, no issues accelerating, only down shifted hard into first one time at 185 degrees. Does anyone have any insight? Never through a code or a check engine light. Truck has never been used to tow either. No transmission services at this point.
    • Atlas won.   I know better, but I did it anyway. I took a compressed air line with a chuck and rubber tip and jammed it in the open EGR port. The port was clear as far as I could see, and as far as I could poke with a flexible wire, but that doesn't mean it's not clogged.   Compressed air blew back at me along with a cloud of black. Oops. I didn't have the rubber tip seated in there all the way. Jammed it up in there some more and squeezed the chuck. PSI was set to 120. Poof! It blew back at me again. Third time...pfffffttssssssspffffffsssfffffff, face full of carbon, and then, kind of a thud..and the air stopped spraying back at me. It was now exiting the exhaust with a low shhhhhh sound as it flowed through the pipe. Something broke free. I pressurized the port again, and air flowed.   Made my day.   Long story short on this problem, it's fixed. Something was really blocking the EGR passages down low, and compressed air blew it apart. I don't recommend this as who knows what debris was sent where. But it's allowed me to move forward, mentally, and onto the next problems I need to get this little S-Blazer going down the road properly again.
    • Your truck lowered, looks good. I'm happy with the stance on this. I may need the extra ground clearance given my location/situation.
