Dreaded Service 4x4 Message
I ran through some high water on the way home. Service 4X4 light came on the dic... I was in Auto mode when this happened. The messages went out, but the truck will not switch back to 2wd. I did not try to switch to 4H or 4L as I feared getting stuck in one of those modes. Is it possible that the water caused a fuse to blow or something? I've done some searching here and everyone says to replace the switch. The lights are working on the switch. Really got me worried that the sensor motor might be bad. Any ideas?
Prob a wet sensor or something. I would drain both differentials and re-fill though.
Sorry, I went back to edit. Both the front and rear differential. If the sensors got wet, then you were in deep enough water to nearly submerge the differentials. They contain your drive gears. If the fluid gets water mixed in with it, it no longer lubricates as it should, allowing your gears to wear prematurely and incorrectly. They are easy to drain and fill back up.
4" deep? And you are having issues? Thats strange as I have been in water/mud to the bottoms of my doors and no issues. I did have to drain the fluid of the diffs just in case but thats it. Maybe you splashed water somewhere....not sure on this one.
If it's under Warranty, take it in.
+1 Take it to the dealer if it is. 4" is not deep at all, barely enough to get to the hub assembly. How fast were you going?
HA, barely enough to get up over the tire and touch the wheel at all.
Doing about 40mph. Another car was beside me so I couldn't just change lanes. Good news is this morning I put the truck in neutral and the switch changed from Auto to 2wd on its own. Put back in park and it switches back and forth now as it should. I'm going to try the 4X4 this evening to make sure everything is mechanically working ok. As far as warranty.. 50938 miles... I'm guessing I'm just out of warranty.
Gotcha...glad its working again. Sensor could of dried out, a solenoid could of been stuck, ect. Powertrain warranty, which should include the transfer case, is good up to 100,000 miles.
If it persists try the switch. Mine SIC said the same thing and it turned out to be just the switch. It is very easy to do.
    • I agree with Tim.  As tech heavy as engines are these days, no way I’d be an early buyer of the new 6.6.  Of course, I bought my ‘26 Denali w/the 6.2 after dumping my Tundra with it’s defective 3.5 liter imploding engine disaster, so I’m a little gun-shy.  That said, my 6.2 has been rock solid.  I don’t drive it like I do my BMW Z4 M40i, but I don’t baby it either.  I got a V8 for a reason.  But I’m averaging 18 around town and 22 highway.  I have seen 24 highway as well when I wasn’t loaded up heavy.  Considering my Tundra with the twin turbo V6 only got 14.5 in town and 17 on the road, I’ll take the 6.2 all day, every day.  If I were you, I’d grab a ‘26 while you can.  Inventories are probably gonna start dropping and I’ll bet the deals will start looking sweeter as well.
    • I am curious if anyone has figured out a way to add an hard button AUX or 360 Camera switch to the center row of switches. I have a 2021 AT4, and want to split the hill decent button and add a 360 camera button so that you don't have to go into the center display and locate the camera functionality, etc...   My father's 2024 Yukon XL AT4 and it has a hard button, see below. I found this thread on the Yukons, but it seems like there may not be a part number for the 2021 sierras. https://www.gm-trucks.com/forums/topic/255339-adding-hard-button-for-camera-on-2021/ Anyone else figured this out. Seems like it would need to be a custom switch!   I am getting ready to install the auto stop/start eliminator, so would be nice to knock them out at once.     Upvote1Downvote0Go to comments
    • Looks like the entire state is burning. 😬
    • Through the years it hasn't been my typical method as I tried to drop oil on an engine that was hot from having been worked, however that was not always practical and had to fire up a unit and let it warm up reasonably well and drop the oil when I had the time to do it but am referring to not only vehicles but a variety of farm equipment and highway tractors etc. However on a vehicle where one is crawling under it and the exhaust is nearby to ones body and if wanting to pull the plug without danger of being hit with boiling hot oil or attempting to remove a HOT oil filter, its sure safer and easier to not have everything smoking hot and can remove the filter right away when under the vehicle and let it all drain. Of course its not the end of the world if a bit of oil stays in the engine that might have eventually found its way out, I like to get out as much as possible but any oil changes that take place in shops would rarely be sitting around for very long at all before the plug is thrown back in and filter slapped on and oil poured in and sent out the door quick like. There would be very little time spent ( assuming they even did it ) in starting the engine with oil to fill the filter, then waiting to verify the level on the stick. A good reason to check ones oil level shortly after a shop changed the oil on a vehicle just to make sure its correct and to look under for any oil around the drain plug or filter.
    • Cool to see another Vermonter!
