4l60e Sonnax Performance Pack Nib
Im going a different route. Looking for $70 Shipped
Part No.
HP-4L60E-01
PUMP PARTS INCLUDE:
Boost Valve with O-Ring, .490”
Elevated Pressure Regulator Spring
High RPM Pump Slide Spring
1 Spacer
SERVO PARTS INCLUDE:
4th Servo Return Spring
Servo Cushion Spring
Servo Piston D-Ring Kit
CASE PARTS INCLUDE:
3-4 Accumulator Piston Kit
3-4 Accumulator Spring
Servo Release Check Valve
VALVE BODY PARTS INCLUDE:
Forward Accumulator Kit
Accumulator Valve Shim
Twist Drills
ACCUMULATOR PARTS INCLUDE:
1-2 Pinless Accumulator Piston Kit
1-2 Accumulator Inner Spring
1-2 Accumulator Outer Spring
1-2 Accumulator Waved Spring
Accumulator Housing Spacer
THIS PERFORMANCE PACK PROVIDES:
• Shorter shifts.
• Faster line pressure increase and higher overall line pressure
for greater clutch/band holding power.
• Ultra-reliable Sonnax pinless accumulator pistons in 1-2, 3-4
and FWD locations.
• Reduction in high RPM pressure drop-off.
• Unique 1-2 accumulator spring combination for shifts
“with character.”
• Patented 3rd accumulator orifice check valve that gets the
2-3 right the first time, every time.
• Consistent results on every job, with no guessing
on calibration.
• Solution to common wear of accumulators and separator
plate seen in hard-working units.
