You'll want to figure out what part number you need (exact model year, ventilated or non-ventilated seats, color choice) but just doing a simple search online seems to indicate there's still inventory out there.
Maybe do some looking around at online sellers/warehouses and see?
Example:
https://g.oempartsonline.com/oem-parts/gm-seat-cover-84520459
What it did from what you describe sounds a lot like what was happening to the earlier years of the very similar transmission in the Duramax version, out of nowhere it would slam into second gear and I believe then that the repair was to replace the valve body. There was that software that came out which was supposed to sense if certain parameters were not being met and warn the driver that there could be an issue happening in the future but that was not a fix. There were some changes somewhere along the way with the valve bodies but when and how well they have panned out I don't know. The ten speed in the Duramax was out since 2020 so its had a lot more use history vs the gas version. Keep us posted to what GM decides to do with it to rectify the issue.
Now granted the part I'm after is for a 2018, but still fits a 2021 Enclave. We purchased an exceptionally well cared for 2018 Enclave and the only wear item I see is the driver's lower seat cover and it's still in decent shape, I would just like to refresh it. Turns out this shale-colored lower seat cover is discontinued and none are left in the country. Is this a supply issue with GM or are they really discontinuing these items which tend to wear after some use and this would be an ideal time to have them in inventory IMO.
