1989 S-10 4.3 Coolant Temp
I just bought my uncle's 89 S-10 with a 4.3 V6. It has 13,300 original miles and when I brought it home the the coolant temperature was running about 160 F if the gauge is correct. That seems low to me but then it is an older truck. Is this within the acceptable range or should I have the thermostat replaced? I am planning on have the coolant replaced and the engine flushed as soon as I can.
OE thermostat was 195 degree. So it should be at least that temp when completely warmed up. Even if had a 180 it should read higher than 160. Since your changing coolant replace the thermostat, it may be stuck open. If you can get a scanner to hook up to your truck you can read the engine temp that way to see if your sending unit or gauge is off.
You should have a good truck there. The 4.3 is a great motor. I think I'd change all my fluids and start fresh. Transmission, differential, brake fluid (thorough flush), power steering. Of course engine also when appropriate
Get a second "opinion" on the actual engine temperature. Get a thermometer and see if that reads the same temperature. Your coolant temperature sender (newer vehicles sensor) might not be reading correctly. I've had these read on the cool side in the past.
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 461 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
