Best Place To Get A Rebuilt 6.0?
Call the info below, they test everything and even guarantee there stuff, shipping would be easy for them too. I have boughten motors and tyranny's from them in the past and if they say its good its good. There web is www.frenchlakeautoparts.com just don't go off there inventory search.
If you want to rebuild one, Call Randy's Repair heres there link: http://randysrepair.com/default.aspx they can do mods and have a dyno in house, very good people.
French Lake Auto Parts -- 3531 County Road 3 NW -- Annandale, MN 55302Hours: Tues-Fri. 8-5 Sat. 8-1 Closed Sun.-Mon.
(320) 274-8497 (320) 286-2560 (320) 274-3079- FAX
[email protected] E-MAILke Auto Parts
Looking at replacing the engine, where's the best place to find a low mileage or rebuilt one?
Where in Texas are you located?
Good info, thanks
I think that guy you kicked the sh!t outta in that street fight owns the only engine rebuild shop in San Antone. :D
Just curious, how many miles did you get out of the current engine? worn out or upgrading?
