2002 Gmc 2500hd With 8.1l
I have a leak at my right manifold, I can not tell if it's a gasket or cracked manifold.
My question: Should I replace it with something else, header?, stock if it is cracked?
Replacing it I can do in my sleep with ease, just asking for options b4 I tear it down. I would rather not have the truck down for a few days if I have to order something.
Alot of guys on or in here have done shorty headers on there 8.1 with good results, i was just thinking about it also putting headers on. is the truck bone stock? no sense in replacing an old/cracked very restrictive manifold with another one.
Yep it's bone stock. Really don't need more power. I found one set of headers and was not looking to spend $600
Just curious, does your exhaust leak sound like a squeaky belt? My 8.1 is making this racket when it is cold but goes away in a couple minutes. Replaced the belt, topped up the steering fluid and checked for anything loose. Not sure I need to put headers in but it is something to keep in mind.
:lol:
I find that too, but it really loud and I sound like the Clampets driving around town before it warms up.
Hope it's the doughnut and not on the head.
Thanks Hockeypro!
Haven't had time to look at it, I am hoping it's just the donut. When I start it, it's way more noticeable, then as it gets warmer it starts to go away. When I pop the hood you can hear it, butt I just can't pin point it. I'll have to try and find a stethoscope and see if that helps. That way i know what part to order when i do get time.
You guys with all these noises are in for an unpleasant treat... They do leak on the right manifold. I have taken mine off and resurfaced it. Do not have your machine shop do it on a broach surfacer, the manifold is too hard. It must be done on a belt type sander that aluminum heads are done on. Someone wrote the exhaust leak went away when hot.... they get louder hot due to expansion. I cannot speak for others but the ticking cold sound is not piston slap on these engines( at least not mine). The noise is valvetrain, and as of yesterday my 45 second cold start up "ticky, ticky " has developed into a "sick to your stomach" rap that is either a lifter colapsed or a rocker arm. If you have these sounds, pull a rocker cover and remove one or two rockers and inspect them. You will be surprised at what you find. No one seems to question the strangeness in that, they actually start up quiet and then begin to tick after about five seconds then it goes away after 45 to a minute. A piston skirt is would be there right away and is a softer lower sound. Mine is comming apart, I don't feel I can trust it any longer. Believe me or not, I used to ignore my little noises but I can't any longer. Maybe I should have bought the diesel.
Whoah hot rod don't go telling me stuff like that, I need sleeping pills as it is!
rev353, we are going to try some soapy water when the truck is cold to try and locate the leak if that is the culprit. I hope I don't end up hot rods grief.
    250.3k
    user087
    user087
  • Who's Online   1 Member, 2 Anonymous, 811 Guests (See full list)
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
    • The not as clean as one would assume theme with the new engine oil, that reminds me of comments over the years with mechanics not always being so on board with filling an oil filter, not from the center anyway due to that typically being the clean side of the filter, danger of some contaminant falling into the filter if not careful but the realization now that the oil may not be as pure as one had assumed it would surely be. Yes it would be possible to fill from the small holes but that means messing with something to prop open the anti drain back valve if the filter is so equipped and not damage that valve in the process. Me, I have hardly ever prefilled an engine oil filter however I have prefilled diesel fuel filters with a filter on a fuel bulk tank and for anyone that has messed with diesel engines with filters and units that have a limited or no way of priming them, putting on a dry filter is a bad day to say the least with those crappy systems. But anyway back to not so clean engine oil, indeed perhaps its not so bad after all that I have not made a practice of prefilling oil filters.    As Grumpy Bear commented on keeping things clean, that I really have to wonder what the typical practice is at a dealer or any other shop that changes engine oil, do they make sure to wipe or wash off the oil plug and certainly if it fell into some gunk or onto a dirty floor, or that they wiped the filter mounting flange and didn't go and use some dirty rag and end up adding dirt to the inside of the head of the filter mount. Or be careless in how they stored or handled the new filter and if they were bumping into items under the vehicle with the filter opening facing up and having dirt drop right into the filter and if so right into the threaded center that is on the clean side. The top side, did they clean away the built up gunk that may be around the filler before removing the cap or to be really careful at that point that something right close to the filler hole that was hidden under the caps flange won't fall into the engine. Or did they clean the funnel or was that just laying there covered in oil from the oil change before and dust kicked up from sweeping the floor stuck to the oil and now that will go running into the next persons engine due to just not cleaning the funnel as "they won't know anyway" attitude as that young guy is more worried about taking a break so he can go outside and smoke a joint. Just random points that came to mind when I think about what some hired personnel may do that the shop foreman has no idea of or perhaps the whole attitude of some shops may be "eh ... who cares, they will never know the difference anyway".
