New Guy From Nor Cal
hey guys! I had a 97 ECSB Silverado z71 w/ a wheatley tune, magnaflow 11" di/do, edelbrock headers. I sold it due to losing my license for unfortunate issues, but I am getting it back in February and am in the market for a NBS Sierra Z71. (preferably CREWCAB)
I am joining early before I get my truck to find out which year would be the best, find out modifications, and what to look out for
Glad to be here :chevy:
