My 08 Silverado 5.3 Rcsb 1/4 Mile Times...
08chev
i'm running pacesetter lt's, magnaflow muffler, cai, and a diablo tune.
60ft... 2.65
0-60... 6.7
1/4... 14.9 @ 93.2
my buddy has the same truck but ex cab & bone stock he went 16.39 @ 90.4 the same day.
i'm also running 22" wheels & 285/40/22's, i know thats holding me back, but other than that how do the times look??? what are you guys getting out of your trucks??? thanks in advance for any input...! :chevy:
60ft... 2.65
0-60... 6.7
1/4... 14.9 @ 93.2
Which gears?
That's right about where you should be with those mods. Ditch the heavy wheels and it will knock maybe a few more tenths off.
Which gears?
3.73.... i think a gear set or torque conv. should be next on the list.... i can't ditch the wheels, they make the truck! :chevy:
  • 1 month later...
At least get some wheels to run down the track...
I'll be using rims like these STOCK 16" on the track:
I'm currently using them to drive around on since i destroyed my 33x12,5R16,5 :P
  • 5 months later...
Did u notice a good gain from the diablo tune?? I have an 08' CC and am looking for a tune. I cant make up my mind, just trying to get feedback from everyone. Thanks.
what makes the truck is that big metal block under the hood :D get a different set of wheels for the track, your choice, speed or not so fast ghetto cruiser...
60ft... 2.65
0-60... 6.7
1/4... 14.9 @ 93.2
i'm also running 22" wheels & 285/40/22's, i know thats holding me back, but other than that how do the times look??? what are you guys getting out of your trucks??? thanks in advance for any input...! :D
0-60 in 6.7 sounds pretty damn good. My 1988 IROC 350 was rated at 0-60 in 6.5 seconds. I didnt test it myself, but that is what the rags always listed its times at.
08 gmc 5.3 ecsb A4
blackbear tune, intake, magnaflow exhaust
15.8 on 22s
on 17s:
r/t .051
60' 2.341
330 6.597
1/8 10.013
mph 72.000
1000 12.937
1/4 15.378
mph 94.63
next mods will be longtube, a stall and servo and a bigger tranny cooler.
what's your reaction time?
you need to get that 60ft down too. when I had my 22s on 305/40s i had a 60ft of 2.2
08 gmc 5.3 ecsb A4
15.8 on 22s
on 17s:
r/t .051
60' 2.341
330 6.597
1/8 10.013
mph 72.000
1000 12.937
1/4 15.378
mph 94.63
went from Vette servo to Billet, well worth the money..
Im running a 14.4 with a Volant CAI, Borla Cat Back and Edge programmer.
On Stock 18's 3.73's
Short box/reg cab
Edit: Ran 15.3 stock... before bolt ons
  • 2 months later...
60ft-2.1
1/4mile-14.07 @98mph....
i cant get it to hook... she gets a little sideways 1/2 shift... and leaving in 4hi is not an option.. so no need to ask why didnt i leave in 4wd...
and yes its in the LOUISIANA Heat and HUMIDITY... i cant wait till i run this baby in the fall with some cool temps...
just in case anyone was wondering what a 6.2l 4dr 4wd would do...
see mods under pic
So why didn't you leave it in 4hi :)
LOL, removed TM and some transmission tuning........ I kind of like my transfer case in one piece... Im sure it would hold, but I rather loose a little tire and Elapsed time than a transfer case, front drive shaft, front chunk, or constant velocity joint.... :lol:
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
