Questions About My New Truck
Hi all,
Picked up a 2008 Chevy Silverado 1500 LT1 Crew Cab last Friday and after driving it around this weekend, I have some questions.
1) Have some creeking noises coming from the right rear leaf spring. Most noticeable at starting and stopping, but I can make it do it by pushing down on the rear bumper as well. Is this a common problem? If I take it to the dealer, will they fix it under warranty?
2) I've only had the alarm go off on me a half-dozen times so far :chevy:
I want to unlock the truck with my key, but it beeps at me when I do that. I think I've figured out that if I lock the truck with the fob button once, I can unlock with the key. But, if I hit the lock button twice (making the horn sound), I will set off the alarm if I unlock with the key. Is this normal operation? Is there a setting somewhere that will allow me to unlock with the key no matter what without getting beeped at?
3) The radio confuses the crap out of me. I have something like 6 pages of favorites, and I like scrolling through the presets on a given page with the steering wheel controls. BUT, I got it stuck on page 6 somehow (all of the stations on that page are XM, and I don't have XM, so it doesn't seem to like to go anywhere). How do I select my favorites page?!?!?!
4) The drive back from the dealership on the freeway netted me ~19mpg. Added a bug deflector and took off the lower front airdam and now down to about 18mpg (although that was loaded with 5 guys and gear). We'll see how things stabilize...
5) Interested in getting some window vent-visors...any recommendations on brand and style? Do the 'push-in' ones work well? Not create much extra noise?
6) I'll get my act together and post some pics in the next couple of days...
Appreciate the help!
-Steve
    CaptainDad
    CaptainDad
  • Who's Online   7 Members, 0 Anonymous, 566 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
