4l60e No 2nd Gear 99 4x4
truck was purchased with no 2nd or reverse,found and replaced broken output reaction carrier and sun gear.have reverse now,but still no 2nd!!?it winds up in 1st and will only shift after letting off throttle.will not shift into 2nd manually either.any help would be great thanx in advance.
IS the 2nd gear servo good? did you take a look at the 2 - 4 band when you had it apart?
i replaced band servo looked fine visually
what about the selinoids? you replace any of those?
no, but have pan off and went thru and double checked all solenoid connections.I am looking for any diagnostic info on solenoids,is it just a continuity check thru the coil or is there a way to ck solenoid function.also would like valve body/solenoid layout if you know where I can find one that would be great,thanks for the help
