Where's The Horn?
I wanted to locate the horn without blowing it in my ear.....where is the darn thing? It is kinda quiet at hwy speeds. I'd like to replace it with a louder one.
There are two of them. They are up high behind the corners of the front bumper.
I think I found one on the passenger side....if there were two there aren't now. I think that might be the problem...eitehr that or one is disconnected.
Maybe you should add one of these. :thumbs:
The other one is on the drivers side right under or kinda beside the windshield fluid bottle. If you look down one of the small openings in this area you can almost see a portion of the horn.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
