New 09 Truck Snow Plow Prep ?
as part of the snow plow prep package it says: SNOW PLOW PREP PACKAGE includes 15-amp power for backup and roof emergency light.
in the manual for the aux.roof mounted lamp it says it is fused at 30 amps.
my questions is,is there an additional fuse set up for aux.back up lights(15a) ? if so does anyone know if the truck is wired for them ? just want to know if i have to run wires for back up lights ?
another question,what is a good place to pick up key-on power to feed relays for accessories ?
thanks
this is on a gmc sierra sle 2500hd ccsb 4x4
I think it might be easier just to tie into your brake harness for reverse wires, then hook lights to that. Get yourself some LED's for back up lights. I have them in my tail gate LED bar and they work really well!
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
