Rims: Do Aftermarket Rims Have Any Certifications?
Spurshot
I haven't dabbled in the aftermarket rim arena in many yrs. Many yrs ago SEMA (specialty equipment manufacturers association) had some basic standards for wheels that were voluntarily met and labeled.
Is there any NHTSA or other safety standards that aftermarket wheels have to meet today? With all the Chinese and other foreign junk that is coming in, I'd be worried about buying wheels that I didn't have some way of knowing were (1) properly engineered, (2) tested, (3) met some kind of quality standards.
Anyone else worry about going 90 mph on wheels made by Mi fook utoo?
I ran across this on a MPVClub.com site.
The following is a Los Angeles Times article addressing safety and alloy wheels. I am putting it on the Problems section because it cites a 2000 MPV as an example of a vehicle that has had a problem, and because some MPV owners have complained of vibrations--though they were typically on fairly new vehicles and this article refers to vehicles(wheels) that have been around for a while and probably taken some abuse.
Interestingly, they refer to alloys in cold weather having trouble keeping air. I was under the impression that it wasn't the cold that caused the problem, but corrosion from road salt that made it more difficult to have a good seal between tire and rim. My father has sworn off alloy wheels due to too many problems with slow leaks.
Anyhow, I figure if you understand the (potential) drawbacks of the components of your vehicle, you're that much ahead of the game.
YOUR WHEELS
Alloys Raise Safety Concerns
By RALPH VARTABEDIAN
TIMES STAFF WRITER
September 11 2002
If you are one of those drivers who makes a practice of bashing into curbs while parking, you might not want to invest in an
expensive set of alloys.
Some experts are less than enthusiastic about the longevity of alloys in general, and they voice concern about their tendency to
sustain damage from abrasion and their problems holding air pressure in tires.
An equally great concern involves the efficacy of repairing damaged alloy wheels.
Replacing a damaged or defective alloy wheel with a new one can be expensive. They can range from about $100 apiece for a
really basic model to well over $500 for a complex design. Alloys come as standard equipment on about 60% of new cars.
Many companies, large and small, sell repaired alloys, taking your damaged wheel in exchange and later repairing and reselling it. In many cases, these repair businesses are providing replacements that had only cosmetic damage, such as scuff marks. But they also sell wheels that have been repaired after being cracked or bent.
A consumer has no way to know how much damage a remanufactured rim had sustained.
Whether it is safe to repair a bent rim is questionable.
The National Highway Traffic Safety Administration has little to offer. The agency's Web site could not locate a single
document dealing with the issue. It does not have standards governing either the manufacturing or the repair of alloys.
"In general, we do not regulate repairs," a spokesman said. Consumers basically are on their own.
Clarence Ditlow, executive director of the Center for Auto Safety, said alloy wheels generally lack consistent quality and often
are subject to fractures. Ditlow said the center has received reports of alloy wheels that are unable to retain air pressure. In
cold climates, tires mounted on alloys with a poor seal can lose significant pressure in as little as one week.
Millions of damaged alloys are repaired each year at a cost of hundreds of millions of dollars, industry sources say. Insurance
companies, for instance, often will specify that body shops use repaired alloy wheels, rather than new ones, when doing
collision repairs.
But most consumers' problems with alloys result from road damage from potholes, curbs or debris.
A typical complaint came to Your Wheels from a Tustin couple, who wrote that their 2000 Mazda MPV minivan began
vibrating at high speeds. After some unnecessary repairs, including an alignment, the vibration was traced to a dent in an alloy wheel.
A major national tire chain estimated the wheel would cost $400 to replace. A smaller tire dealer offered to repair it for $250.
Finally, the couple had the wheel fixed by an independent repair operation for $100.
The repair industry includes small shops that do little more than sand scuff marks off wheels and very large corporations that
operate factories that perform major repairs.
Transwheel Corp., which describes itself as the largest vendor of repaired alloy wheels in the country, annually repairs about
150,000 of them, according to Jim Devlin, general manager of operations.
Devlin said the company does repair cracks and dents, but within strict limits, and has developed its own internal standards to
determine the severity of damage that can be safety repaired. Devin said the company removes up to 20 thousandths of an inch of metal in some resurfacing operations, using computer-controlled machines.
Independent tests, he said, have shown that wheels repaired to such standards meet requirements set by car makers and by
the Society of Automotive Engineers. But such assurances do not satisfy everyone.
Ken Zion, owner of Automotive Collision Consultants, a private accident investigation company in Long Beach, expressed
concerns about the use of repaired alloy wheels. In some cases, remanufacturing companies have taken excessive amounts of
aluminum off the wheels when resurfacing them, leading to failures, he said.
Zion also said he has had many tire-leak experiences with alloy wheels, though none with steel wheels. In general, Zion said he
would not recommend purchasing repaired alloy wheels without knowing the history of the wheel and the identity of the repair
company.
Although many motorists think about tire safety in these post-Firestone recall days, wheel safety isn't such a hot topic. Still, alloy wheels can and do fail, resulting in a loss of control just as severe, if not more so, as if a tire had blown out.
if you stick with a good brand, you shouldnt have issues
Sounds like "good brand" could be about anybody not having a bad rep. Firestone was a "good brand" of tire until the rollover problem. Meeting a real standard gives me more confidence than one that doesn't. Example: Ultra wheels (like Daddy's) meet the SAE standard (voluntary) and Pro-Comp doesn't seem to mention meeting any standard, but gives a "lifetime warranty". If the wheel failure kills you, I guess "lifetime" is over. :lol: Yeah, yeah, I know standards don't guarranty anything, but they do help provide some assurances, depending on how good the standard is.
The sad reality is that even OEM wheels come from overseas. Much of the issue adressed above with leaking wheels is that many oem wheels were clearcoated over aluminum, this is a bad mix when salt is involved. The salt seperates the clearcoat causing a leaky bead mess.
Todd,
Salt and aluminum aren't a good combination no matter whether it's wheels or airplanes (I'm an airplane eng). Coming from overseas isn't damning in itself. Many components in major airplane models are built overseas. It's more a question of good design and quality control. I know that the big 3 us auto makers were buying alum wheels from a CA located company and now either they moved that company's facilities to Mexico or GM is buying from a different company in Mexico.
    tararebecca
    tararebecca
  • Who's Online   3 Members, 0 Anonymous, 538 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
