Front, Rear, Transfer Case Fluids
I'm thinking about changing my front and rear diff. and transfer case fluids on my '08 Max. Does anyone know about how many quarts I need for each one?
Also, I'm wondering what kind of gear oil to use for the front diff. My owners manual says to use 80/90 for 1500 trucks and 75/90 synthetic for 1500hd trucks. Is a Vortec Max considered a 1500hd or not? Or does it really make that big of a difference if I use 80/90 or 75/90 synthetic?
No,The VortecMAX is not considered an HD.
Service Information
2008 Chevrolet Silverado - 4WD | Sierra, Silverado (VIN C/K) Service Manual | General Information | Maintenance and Lubrication | Specifications | Document ID: 1831479
Approximate Fluid Capacities
See Fluid and Lubricant Recommendations for more information. All capacities are approximate. When adding, be sure to fill to the approximate level, as recommended in this manual. Recheck fluid level after filling.
Application
Specifications
Metric
English
Axle Capacities
Front Axle 1500 Series (8.25")
1.43 liters
1.51 quarts
Front Axle 2500 Series (9.25")
1.73 liters
1.83 quarts
Rear Axle 1500 Series without RPO AXN (8.6")
2.03 liters
2.15 quarts
Rear Axle 1500 Series with RPO AXN (9.5" LD)
2.6 liters
2.75 quarts
Rear Axle 2500 Series (9.5" HD)
2.6 liters
2.75 quarts
Rear Axle 2500 Series with RPO LY6 (10.5" )
2.6 liters
2.75 quarts
Rear Axle 2500 Series with RPO LMM (11.5")
3.0 liters
3.17 quarts
Rear Axle 3500 Series (11.5")
3.0 liters
3.17 quarts
Cooling System
4.3L V6 Automatic
15.6 liters
16.5 quarts
4.8L V8 Automatic
16.0 liters
16.9 quarts
5.3L V8 Automatic
16.0 liters
16.9 quarts
6.0L V8 Automatic - 1500 Series
15.9 liters
16.8 quarts
6.0L V8 Automatic - 2500, 3500 Series
16.4 liters
15.5 quarts
6.6L Diesel
23.4 liters
24.7 quarts
Engine Oil with Filter
4.3L V6
4.3 liters
4.5 quarts
4.8L V8, 5.3L V8, and 6.0L V8
5.7 liters
6.0 quarts
6.6L V8 Turbo Diesel, RPO LMM
9.5 liters
10.0 quarts
Fuel Tank
1500 Series Standard and Short Box
98.0 liters
26.0 gallons
1500 Series Long Box
128.7 liters
34.0 gallons
2500 Series Standard Box
98.0 liters
26.0 gallons
2500 and 3500 Series Long Box
128.7 liters
34.0 gallons
3500 Series Chassis Cab
189.0 liters
50.0 gallons
3500 Series Chassis Cab - Front Tank
102.0 liters
27.0 gallons
3500 Series Chassis Cab - Rear Tank
87.0 liters
23.0 gallons
Automatic Transmission Fluid
4L60-E
4.7 liters
5.0 quarts
4L70-E
4.7 liters
5.0 quarts
6L80-E
5.7 liters
6.0 quarts
6L90-E
7.0 liters
7.4 quarts
Transfer Case Fluid
1.5 liters
1.6 quarts
© 2009 General Motors Corporation. All rights reserved.
Service Information
2008 Chevrolet Silverado - 4WD | Chevrolet Silverado Owner Manual | Maintenance Schedule | Maintenance Schedule | Maintenance | Document ID: 1907135
Recommended Fluids and Lubricants
This maintenance section applies to vehicles with a gasoline engine. If your vehicle has a diesel engine, see the maintenance schedule section in the DURAMAX® Diesel manual.
Fluids and lubricants identified below by name, part number, or specification can be obtained from your dealer/retailer.
Usage
Fluid/Lubricant
Engine Oil
Engine oil which meets GM Standard GM6094M and displays the American Petroleum Institute Certified for Gasoline Engines starburst symbol. SAE 5W-30 is best for the vehicle. (GM Part No. 12345610)
If you are in an area of extreme cold, where the temperature falls below -20°F (-29°C), use either an SAE 5W-30 synthetic oil or an SAE 0W-30 oil. Both provide easier cold starting and better protection for the engine at extremely low temperatures. These numbers on an oil container show its viscosity, or thickness. *DO NOT use other viscosity oils such as SAE 20W-50*
Engine Coolant
50/50 mixture of clean, drinkable water and use only DEX-COOL® coolant. See Engine Coolant (GM Part No. 12346290)
Hydraulic Brake System
Delco® Supreme 11 Brake Fluid or equivalent DOT-3 brake fluid.
Windshield Washer
Optikleen® Washer Solvent (GM Part No. 1051515)
Power Steering System
GM Power Steering Fluid (GM Part No. U.S. 89021184, in Canada 89021186).
DEXRON®-VI Automatic Transmission Fluid (GM Part No. - Qt.#88861003 - Gallon #88861045)
Key Lock Cylinders
Multi-Purpose Lubricant, Superlube (GM Part No. U.S. 12346241, in Canada 10953474).
Floor Shift Linkage
Lubriplate Lubricant Aerosol (GM Part No. U.S. 12346293, in Canada 992723) or lubricant meeting requirements of NLGI #2 Category LB or GC-LB.
Chassis Lubrication
Chassis Lubricant (GM Part No. U.S. 12377985, in Canada 88901242) or lubricant meeting requirements of NLGI #2, Category LB or GC-LB.
Front Axle (1500 Series) - Four-Wheel Drive
SAE 80W-90 Axle Lubricant (GM Part No. U.S. 89021671, in Canada 89021672).
Front Axle (1500 HD, 1500 AWD, 2500, 2500 HD, and 3500 Series)
SAE 75W-90 Synthetic Axle Lubricant (GM Part No. U.S. 89021677, in Canada 89021678) meeting GM Specification 9986115.
Rear Axle
Transfer Case (Four-Wheel Drive)
Front Axle Propshaft Spline or One-Piece Propshaft Spline (Two-Wheel Drive with 4-Speed Auto. Trans.)
Spline Lubricant, Special Lubricant (GM Part No. U.S. 12345879, in Canada 10953511) or lubricant meeting requirements of GM 9985830.
Rear Driveline Center Spline
Hood Hinges
Body Door Hinge Pins, Tailgate Hinge and Linkage, Folding Seats, and Fuel Door Hinge
Tailgate Handle Pivot Points, Hinges, Latch Bolt, and Linkage
Weatherstrip Conditioning
Weatherstrip Lubricant (GM Part No. U.S. 3634770, in Canada 10953518) or Dielectric Silicone Grease (GM Part No. U.S. 12345579, in Canada 992887).
Weatherstrip Squeaks
Synthetic Grease with Teflon, Superlube (GM Part No. U.S. 12371287, in Canada 10953437).
Do you think there would be any harm or any advantages in putting the 75W-90 synthetic oil in the front axle and synthetic oil in the transfer case?
