Fan Blower Control
I have 2003 HD 2500, the A/C & Heater blower control is erratic.
When the vehical is just idling and sitting still the blower quits.
When I travel down the road it comes on but only works from 1-4 speed won't work on 5 at all anytime.
What's the cure?
  • 7 months later...
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
