Question Concerning Bb Tune
I'm planning on putting 285/70/17's on my truck and just thought about if I need to have the bigger tires put on before the tune or if I'd be okay putting them on afterwards?
Yeah I'm running the stock 265/70/17's right now because well I paid 30k for them :) and they are perfectly fine. But I was planning on getting bigger tires (285/70/17) and didn't know how much it would affect the tune.
But I guess it does make sense to go ahead and have it already switched over so everything is how it should be from here on out.
The tire size won't really effect the tune. But, the tire size different will throw off the speedometer, MPG calculations, etc. So, it's a good idea to get the computer adjusted for the new tire size when you get the tune done.
You can do it either way. I'm running stock tires and have a BB tune. I'm switching tires soon. It'll change the odometer/speedometer, but shouldn't make any difference in the engine tuning and negligeable difference in the trans control. Once you put the tires on, you can have BB make an adjustment with an exchange TCM.
Or you can wait and do it after the tire switch. There's no real downside either way. 'just depends on how long you're going to be before you get tires. If it's a while, go for the tune now.
Seth, which transmission is in the truck? I'm seeing a 2009 crew-cab, which makes me think it's probably a 6-spd. If that's the case, you can't do a TCM swap, like Chuck is suggesting. The TCM is inside of the 6-spd transmissions. If it's a 4-spd, though, you're in luck. You could do a TCM swap and send the TCM off to BB for retuning.. Of course, you'd need a spare TCM to be able to do that or the truck would be down for a few days, while you wait (since it needs the TCM to control the transmission, so you can drive it).. Since you're even considering the tires in the equation, that makes me think you're kind of close on doing the tires.. If that's the case, I'd just do the tires now (or at least before the tune).. That seems like the easier route, to me.. :)
Yeah its a 6-spd so I couldn't send it off. I'm going to do the tires thats a for sure yes, but since I'm a full-time student in college and I'm paying my truck note, so the upgrades are coming in stages.
I might just borrow a little money from the parents and get the tires before the tune so I can have it done how I want it and not have to worry about getting a re-tune at a later date.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
