Backspacing Question?!?!
hey guys, so right now i have 18x9 XD diesel wheels with 5 inch backspacing, the tires are 33x12.5 and do not rub at all. I am looking into buying a set of weld cheyennes someone has for sale. The only thing is these are 12 inches wide with 4.5 inch backspacing, the tire will still be a 33x12.50. Does any one know if i can clear them? The tires i have right now are about an 1.5 inches away from my fender at the closest point. please if you have any idea or similiar wheels let me know what you think. Thanks
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
