Keyless Entry Issues
Hi All! I need help troubleshooting my keyless entry on my 2007 Yukon. Does anyone know where I can find the module that receives the keyless radio signal? Is this a serviceable unit or can I replace it? I'm thinking it has to be that unit because the remote key and TPMS both went out at the same time and now it will not re-learn the remote key in the DIC.
Thanks for your help.
Roger
  • 5 years later...
I believe the BCM is located behind the glove compartment.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,119 Guests (See full list)
